SES Light P0313 - Misfire Detected with Low Fuel - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 07-30-2007, 06:03 AM
sierrakilo99 sierrakilo99 is offline
Send a message via AIM to sierrakilo99
Mein Auto: 2008 328i/1989 Civic HB
Ok, I've been trying to research this OBD-II code for a couple of days now, haven't really found anything 'firm' on the cause of this code, so before I start blindly replacing components and the cost climbs exponentially, I'll throw this bone out to the bimmerfest hounds.
As the title says, I've got a Service Engine Soon light lit up like a christmas tree on the panel... you know, can't take your eyes off of it even though the car runs fine and I'm getting good gas economy, not running rough etc. I got Autozone to read the codes and clear them for me a couple of days ago, but they just came back within a day.
The Autozone OBD-II scan tool says its a P0313 Misfire Detected with Low Fuel. Yes, I did run the tank down til the idiot light came on the day after AZ cleared the codes, but I did not run it dry, nor even close. I just turned 64k miles on the car this weekend, the next service due (according to the dash display) is an oil service in 7,000 miles. I had planned on doing the oil change when I hit 65k miles, but the SES light came on first.
So, anyone else ran across this one? What is the most likely cause of this OBD-II code and what did you do to clear it completely? I can understand a misfire (possible bad spark plug, etc.) but the 'with low fuel' means nothing to me...
BTW, I'm pretty handy with repairing my own vehicles, so nothing (except having to pay the dealer) scares me about working on my own car.
Old 07-30-2007, 08:19 AM
Vornado's Avatar
Vornado Vornado is offline
Protect your (lug) nuts
Mein Auto: '97 BMW 328i
I've been baffled with with issue as well. I assume your car is running fine, yet this code keep coming up? I wasnt sure how I fixed mine, but it just went away after a while. I cleaned the fuel system, intake valves, and stopped using a certain gas station, and it just went away. Dunno what causes it.
If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them.
-- Henry David Thoreau
Old 07-31-2007, 05:56 AM
That's pretty much what's going on... the SES light comes on for a few days, goes off by itself. I haven't done anything to the car except put gas in it the four weeks I've owned the car. I'm planning on doing the 60K mile service to it this weekend. Hopefully changing the plugs and the filters will put an end to the light... some one recommended putting a can of fuel injector cleaner into the tank, but I haven't tried that yet.
There was one other post that came up in my search results that reported the same code, but they also had three or four other codes that were reported at the same time (I don't have that going on, just this one). That poster had taken the vehicle to the dealer, and only after chasing about $1000 worth of 'service' did they 'fix' the problem.
http://www.bimmerfest.com/forums/sho...sfire+detected
LOL - the dealer calls parts swapping until the problem goes away 'dealer service'... I guess no one does old fashioned 'trouble shooting' before blindly replacing parts these days.
Old 07-31-2007, 07:00 AM
Vornado's Avatar
Yup, thats a dealership for you. The only time I'd take it there is when I'm under full warranty and they give me a loaner. Actually the dealership I go to the service is above par compared to others I've dealt with. Before I became savvy, it seemed every time I took it to one place, my car would come back with something else mysteriously wrong with it, every single time.
I'd go with some fuel cleaner, make sure its a good kind though, and not that cheap $2 stuff. Also look into changing the fuel filter if you're doing 60k service.
Old 07-31-2007, 09:37 AM
Vampo Vampo is offline
Mein Auto: E46 318i 2002
Are these fuel cleaners good for your vehicle ? I was told by the dealer not to use any saying that it's one reason that causes problems in BMWs. I'm not sure about this advice from the dealer so please let me know about your thoughts ?
Old 07-31-2007, 11:08 AM
Which fuel injection cleaner did you use? I've always used something like Prestone's in my Honda's and Ford's. It's not $2/bottle, more like $7 around here (Central FL). Or does BMW recommend some other brand?
Old 07-31-2007, 05:59 PM
Vornado's Avatar
I dont remember, valvoline something.. Anything should work. Just cause its a BMW doesnt mean you have to use BMW brand or anything.
Old 05-26-2008, 05:09 PM
Tpoulton Tpoulton is offline
Mein Auto: 2004 325i
I have the same issue. If it sits for a while, it has long crank then starts and runs fine. When I fill up the tank it seems to get better for a while and then it comes back. I am going to try a fuel cap.
Old 01-22-2015, 08:55 AM
Brianbimmer Brianbimmer is offline
Mein Auto: Dropped 325ci e46
I got the p0313 and p0300 have you solve your problems?
Old 01-22-2015, 11:01 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
See also:
- How to diagnose a BMW engine misfire (1) & a cold-engine intermittent misfire (1)
