E36 (1991 - 1999)
Old 08-06-2007, 03:26 PM
SLYKEST SLYKEST is offline
Mein Auto: 1997 BMW 318is
Brake Lights not working and (Check Engine light on)
Thanks for all the help in the past. I now require help once again. I have a 1997 BMW 318is (E36) My break lights are not working. I changed the bulbs and still nothing. The turn light works, the reverse light works and the running lights turn on when u turn on your head lights on both sides but when u press the brake peddle no brake light on both sides. I got the bulbs from a autoparts store and still nothing. I checked the fuses up in the engine area and they are all good.
Second issue is my Check engine light, its been on for about 2 weeks but im not sure what the problem is or how to find it. I read alot of posts on here and they is it could be the O2 sensor is that possible?
Thanks for all the help and advice in advance.
Thanks,
JR
Old 08-06-2007, 04:07 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Hey buddy, the check light is probably for the failing lights. Best get your codes pulled
The E36's had well documented rear cluster issues.
Have you checked your fuses? Your brake light switch may also be on the blink...mine was
2001 Mini Cooper R50
Edirty6 for life
Old 08-06-2007, 04:13 PM
The fuses are fine I check'd them, how can I get the codes pulled? Is there a DIY for the Brake light Switch?
Old 08-06-2007, 04:16 PM
Still here
Mein Auto: M3
You will need to take your car to a BMW specialist with the equipment or by a peake/draper code tool to get them mate
Here is a DIY for the switch - http://www.pelicanparts.com/bmw/tech...ake_Switch.htm
Edirty6 for life
Old 08-06-2007, 04:18 PM
VTi's Avatar
VTi VTi is offline
Dale Crane is the MAN!
Send a message via AIM to VTi
Mein Auto: 95 320i / 00 520i
more like, they are linked to a LOT of homicides lol
Old 08-06-2007, 04:19 PM
Still here
Mein Auto: M3
lol , +100
Edirty6 for life
Old 08-12-2007, 05:48 PM
It was the brake switch.... thanks for all the help... it was very easy to install but u just have to break the old one.. THANKS FOR THE HELP ONCE AGAIN....
Old 08-12-2007, 05:53 PM
Still here
Mein Auto: M3
Edirty6 for life
Old 08-12-2007, 05:55 PM
SewerSideUp's Avatar
SewerSideUp SewerSideUp is offline
Spitfire
Mein Auto: 94' 318iS
And another one by the Guru's at BimmerFest !!! SOLVED ! ! !
God I love this place !!!
Old 08-12-2007, 06:07 PM
Still here
Mein Auto: M3
Quite fond of it myself
Edirty6 for life
Old 08-12-2007, 06:30 PM
Spitfire
You should, almost 7,800 posts !!!! And counting. And almost the same number of problems solved !!! Guru's I tell ya !! Guuruu's !!
I really want the Bimmerfest.com stickers on my baby.
Old 08-13-2007, 02:30 AM
Still here
Mein Auto: M3
Get them!!
Edirty6 for life
