E30 (1982 - 1993)
Old 08-08-2007, 08:31 PM
Xkalibur7 Xkalibur7 is offline
Xkalibur7
Mein Auto: 2002 BMW M5 Carbon Black
Question Tools Needed for Brake and Rotor Change
I'm getting ready to change my rotors and brake pads
Are there any special tools i'll need to do the job on my E30
I also have new rear wheel bearings, are they difficult to replace and will i also need more special tools to do the job?
I have the bentley manual, but it likes to refer to BMW tools to remove or change the above listed parts. CAn i possibly get the parts i need from an auto parts store?
Thanks for your help
All Throttle and NO Bottle!!!!!
Old 08-09-2007, 10:54 AM
Mike_Check Mike_Check is offline
Account close at users request
Mein Auto: .
A good set of hand tools will do the job. Including allen wrenches, star bits, and a good leverage pipe. You may need a rubber sledge if your rotors havent been off in a while.
Old 08-09-2007, 12:32 PM
omw41's Avatar
omw41 omw41 is offline
Mein Auto: 1986 BMW 325 E
Thanks! I'm doing the same job this weekend! Why the leverage pipe though? Do you mean a breaker bar????
Old 08-09-2007, 01:58 PM
Xkalibur7
Thanks for the replies, i should have most tools, i'll need a decent leverage pipe... i would assume that is to disconnect the front from the steering and drive shaft? Will this job be difficult to do without a lift? Lastly, are there any lubricants, grease, or oil i will need to replace or use on the parts? I'm almost certain i'll need some of those... i am just not sure what to use on BMW's... always have to check with these cars before i do something stupid! Thanks
Old 08-09-2007, 02:33 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
You don't need a breaker bar for pads/rotors. I've never changed my wheel bearings so I can't help with that.
Click Here for some really good brake-related DIYs
I Timothy 2:1-2
Old 08-09-2007, 04:31 PM
Mein Auto: .
AH! Thats the word I was looking for! I couldn't think of it.
Old 08-09-2007, 04:33 PM
Mein Auto: .
I did.
The bolt holding the rotor on was fused to the rotor and hub. I used a torch...PB Blaster, anything you can think of...then I got out the PipeZilla. My 3.5 foot lead pipe...
I did need a new bolt...
and hub...
and rotor.
Old 08-09-2007, 04:37 PM
Mein Auto: .
I only did the front wheel bearings...and it wasn't too bad. Just keep the parts in order as you remove them...keep everything OVERLY greased(drop the bearings in the grease and submerge it), just enough so it wont drip. Clean your rotors and new parts with brake cleaner thoroughly!!!!!!! Oh...use some anti seize on all your bolts, and make sure the caliper slide bolt is greased, and the boot on the caliper slide is sealed. Good luck.
Old 08-09-2007, 07:31 PM
an audience of One
I did.
and hub...
and rotor.
Anti-seize on the hub, too. I hand tighten the allen head that secures the rotor to the hub.
I Timothy 2:1-2
Old 08-09-2007, 09:47 PM
Mein Auto: .
Yeah, I just barely tightened it down, but it started rubbing on the splash guard behind the rotor. Could have been coincidence though, b/c the lugs tighten the rotor on...so,
Old 08-10-2007, 11:33 AM
omw41's Avatar
Good stuff guys. Thanks! I got the turner motorsports brake kit that Mark posted.
Old 08-11-2007, 08:12 AM
Xkalibur7
Thanks Everyone for your help... i'll make sure i have everything ill need before i start the brake and rotor job. I appreciate the good info and lessons learned! Hopefully i don't make similar mistakes.
