E36 (1991 - 1999)
Old 08-13-2007, 05:28 AM
carlos330 carlos330 is offline
Mein Auto: '93 325i
93 325i tranny!*%4
Hey guys here's my problem. Sometimes when i start my car and shift into drive ill let go of the brake and it doesnt go anywhere. I step on the gas and it barely moves anywhere.... I turn the car off and back on again and shift and i here a loud shift and then it finally goes most of the time but sometimes I have to try that a bunch of times. I know this sounds pretty bad but any light from the BMW pros on the site to keep me from would help. Thank you guys n (gals)
Old 08-13-2007, 06:50 AM
Mein Auto: '93 325i
anyone..... (pirate).....
Old 08-13-2007, 06:55 AM
Conehead Conehead is offline
Go you Good Thing
Mein Auto: e36 316I M
Mate, did this happen all of a sudden, or has it been a slowly worsening problem.
If its a sudden problem, I would suggest you check the transmission fluid, make sure the transmission is full (the the required amount) of fliud.
If its low, I would look under the car and see where its leaking from. If its a problem thats been getting worse, I would suggest you take the car the a auto tranny specialist.
Hope this helps
Cone
XXX
The best predictor for future behaviour, is past behaviour. ALSO, IT SHOULD BE NOTED:......AMATURES BUILT THE ARK..AND PROFESSIONALS BUILT THE TITANIC..................QUOTE FOR THE DAY.. Good drivers know how to get out of trouble, and better drivers know how to avoid it.....The Cone 2006 & 2007
Old 08-13-2007, 06:56 AM
Mein Auto: '93 325i
thanks
thanks i'm pretty sure its a recent problem I'll do the suggested as soon as possible ..
Old 08-13-2007, 06:57 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Sounds to be like the parking brake or brakes are seizing
Have you checked your brake fluid level?
Transmission fluid is a good call though and would need to be checked!
330i M-Sport in Topaz Blue
Edirty6 for life
Old 08-13-2007, 07:02 AM
Mein Auto: '93 325i
brakes
I havent checked the brake fluid but now that you mention that when im driving and i let up off the gas it feels like I'm downshifting the car stops very suddenly like I dropped a gear but i haven't
Old 08-13-2007, 02:54 PM
Go you Good Thing
Good call..Didnt think of that
Cone
XXX
Old 08-13-2007, 02:56 PM
Bimrpwr's Avatar
Bimrpwr Bimrpwr is offline
Mein Auto: 93 325 and 91 K2500
if your brakes are sticking you should smell them as well after driving a bit.
Old 08-13-2007, 05:53 PM
SewerSideUp's Avatar
SewerSideUp SewerSideUp is offline
Spitfire
Mein Auto: 94' 318iS
True. Maby it the e-brake stuck at one of its locking clicks ?
In general, check all youre braking hardware at the back(Incl. the pump). And also transmission fluid and filter. You could have a dirty filter but my bet is on the brakes.
Old 08-13-2007, 07:40 PM
jh1328's Avatar
jh1328 jh1328 is offline
<----MY girl....
Send a message via AIM to jh1328
Mein Auto: e36 325i
do you have a girlfriend or a wife? it may just be a physical representation of a woman holding you back from progress
im josh...this is what i drive.
Old 08-14-2007, 07:16 AM
Mein Auto: '93 325i
Where is the transmission filter located?
Old 08-15-2007, 02:21 AM
efanton's Avatar
efanton efanton is offline
Mein Auto: BMW 325TD
Does my car have an E-Brake? it doesn't connect to the internet
It's never too late to have a happy childhood
