Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 08-13-2007, 01:38 AM
tjohnson329 tjohnson329 is offline
Mein Auto: 1998 BMW 740il
All lights dimming out
I am having a slight problem it seems that every now and then y car lights dim out and back in, then my traction control light stays on. All the lights will dim in and out but If i stop the car and restart it it will act just fine for a while. I was wondering what can be causing this problem? If it is at night even the headlights will start to dim with the dash lights but they never totally go out, and no fuses are ever blown. it seems as if I have a overload somewhere or maybe a loose ground screw. Any help will be appreciated thanks.
Old 08-13-2007, 03:38 AM
Adi's Avatar
Adi Adi is offline
Mein Auto: E38 750iL, A6 (4f) Avant
Sounds very similar to a problem I had. For me, it was a faulty alternator.
Audi A6 Quattro Avant (2007) - Oyster Gray Met.
E38 750iL (1995) - Cosmos Schwarz
Sign by Danasoft - Get Your Free Sign
Old 08-13-2007, 04:43 PM
faulty altenator, sounds like it could be, i mean i checked the voltage and it seems to be getting the right voltage but i didnt check it under load when the car was dipping out at all. probaly is the problem thanks alot.
Old 04-20-2010, 03:59 AM
krakadil_gena krakadil_gena is offline
Mein Auto: 545i
Hey tjohnson329, did you solve the problem you had ? I have very simmilar issue ....
- Diming lights when I press acceleration, (this happes in neutral mode as well)
- half lit lights on traction and abs (WTF, overcharging ?!)
-if I run the car in neutral and bring the RPM to quite high, then after some time it all comes to normal ....
I have been suggested that the - SMART CHARGE SYSTEM in the ECU is broken and ECU should be replaced ... which is quite expensive .....
but is it really the ECU problem ??
Can I just disconnect the smart charge system ? How ?
any thoughts ? ok links for more reading ?
thank you !
ya
545i with n62b44 engine
Old 04-25-2010, 03:44 AM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
honestly sounds like the alternator's voltage regulator may be going out. it may not be putting out enough amperage either. you will want to check both voltage and amperage output. most automotive parts stores will do a test for you for free.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
