E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
93 325i tranny!*%4
Hey guys here's my problem. Sometimes when i start my car and shift into drive ill let go of the brake and it doesnt go anywhere. I step on the gas and it barely moves anywhere.... I turn the car off and back on again and shift and i here a loud shift and then it finally goes most of the time but sometimes I have to try that a bunch of times. I know this sounds pretty bad but any light from the BMW pros on the site to keep me from
would help. Thank you guys n (gals)
anyone..... (pirate).....
Mate, did this happen all of a sudden, or has it been a slowly worsening problem.
If its a sudden problem, I would suggest you check the transmission fluid, make sure the transmission is full (the the required amount) of fliud. If its low, I would look under the car and see where its leaking from. If its a problem thats been getting worse, I would suggest you take the car the a auto tranny specialist. Hope this helps Cone XXX
ALSO, IT SHOULD BE NOTED:......AMATURES BUILT THE ARK..AND PROFESSIONALS BUILT THE TITANIC..................QUOTE FOR THE DAY.. Good drivers know how to get out of trouble, and better drivers know how to avoid it..... The Cone 2006 & 2007
thanks
thanks i'm pretty sure its a recent problem I'll do the suggested as soon as possible ..
Sounds to be like the parking brake or brakes are seizing
Have you checked your brake fluid level? Transmission fluid is a good call though and would need to be checked!
330i M-Sport in Topaz Blue Edirty6 for life |
brakes
I havent checked the brake fluid but now that you mention that when im driving and i let up off the gas it feels like I'm downshifting the car stops very suddenly like I dropped a gear but i haven't
Good call..Didnt think of that Cone XXX
if your brakes are sticking you should smell them as well after driving a bit.
True. Maby it the e-brake stuck at one of its locking clicks ?
In general, check all youre braking hardware at the back(Incl. the pump). And also transmission fluid and filter. You could have a dirty filter but my bet is on the brakes. |
do you have a girlfriend or a wife? it may just be a physical representation of a woman holding you back from progress
im josh...this is what i drive. |
Where is the transmission filter located?
Does my car have an E-Brake? it doesn't connect to the internet
It's never too late to have a happy childhood |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
