E36 (1991 - 1999)
Old 08-13-2007, 11:03 AM
RAMMROD RAMMROD is offline
Mein Auto: 325I
Alt. light on
I have a 1994 325i 134k mi.
The Alt. light is on and it isn't the alternator. Last week I replaced the starter, way harder than it should be. The car ran great but the alt light was on. So i tested a few things and settled on replacing the alternator. The light is still on!. The engine ground is good. The battery is less than 12 mo old. The battery voltage is 12.3 with the car off and 10.8 with it on. What else should I check?
Old 08-13-2007, 11:14 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Hey buddy
What do you mean by your alt light? you mean the battery light?
You could try the pedal trick to see if any codes are held, it may work with your car
To run through the 4-digit code data on your car, put the key in the ignition and turn to the 2nd position, where all the cluster lights come on. Within a second, tap the accelerator pedal (fully) 5 times in rapid succession (total time about 3 seconds). The check-engine light will flash once and then turn off. It will then flash a certain number of times, turn off, flash another number of times and then do it twice more. If there are other codes it will then flash these. For example.... "flash... flashflash... flash... flashflashflash" would be a code of 1213 (whatever that is). If your car is telling you certain codes, you can crossreference these codes online and see if they mean anything's wrong. You will need to know the exact year and engine in your car when you search for a code list, as they differ by engine.
2001 Mini Cooper R50
Edirty6 for life
Old 08-13-2007, 01:10 PM
Mein Auto: 325I
Yes the battery light, the alternator isn't charging. There are no code faults.
Old 08-13-2007, 01:21 PM
Still here
Mein Auto: M3
Doh!
Have you checked the belt is tight enough?
Edirty6 for life
Old 08-14-2007, 10:41 AM
Mein Auto: 325I
Yes the belt is tight and my ECU is very dry.
Old 08-14-2007, 10:45 AM
Still here
Mein Auto: M3
funny
Edirty6 for life
Old 08-14-2007, 12:15 PM
bobbobb bobbobb is offline
Mein Auto: 318tdse
the battery should read about 14.5 with the engine running
sounds silly but 1st how do you know its not the alternator? and when you replaced it did you put all the wires back on?
just a start so we know
Old 08-15-2007, 12:13 PM
Mein Auto: 325I
I replaced the alternator with a new one. I assume since both alternators (the original and new one) weren't generating current it's not the alternator. Yes, both wires are on and tight. Are there any other components involved? Relays ect.
