E36 (1991 - 1999)
Old 08-14-2007, 12:13 PM
nelson22's Avatar
nelson22 nelson22 is offline
old people=roadkill
Mein Auto: e36 318i 1996
starter problem
any one give me advice on my starter motor
when the engine is cold i have no probs at all
starts up straight away
after a drive i switch the car off when i go back to the car (engine still warm)i turn the key the starter kicks but then it just spins as if not engaged takes a couple of goes to get it to engage
any ideas
projector angel eyes-strut brace-lowered 40mm-ram air induction filter-custum heat shield-17"alloys-gen 3 mirrors-lexus rear lights-full black leather-iridium plugs-royal purple
Old 08-15-2007, 08:25 AM
Vornado's Avatar
Vornado Vornado is offline
Protect your (lug) nuts
Mein Auto: '97 BMW 328i
Hmm, Pete passed this thread up. You might need a new starter.
If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them.
-- Henry David Thoreau
Old 08-15-2007, 08:30 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
I did indeed and think the same
Solenoid may need replacing though which is a bit cheaper but unlikely
2001 Mini Cooper R50
Edirty6 for life
Old 08-15-2007, 09:49 AM
SewerSideUp's Avatar
SewerSideUp SewerSideUp is offline
Spitfire
Mein Auto: 94' 318iS
You can find some refurbished ones around. If its not fixable.
Btw Nelson, did the NGK Irridium plugs give you a good difference on youre four-banger ? And what type of difference, power, smoothness, throttle respnse? !?
I know about the torque curve Pirate. Its just that this engine has a bigger counter-wieght on its crankshaft than most engines. Thats the reason behind the good torque but zero horsepower.
Old 08-15-2007, 11:04 AM
Still here
Mein Auto: M3
My lips are sealed then
Edirty6 for life
Old 08-15-2007, 11:36 AM
nelson22's Avatar
old people=roadkill
the plugs are fine they make the car feel better on accelaration a lot smoother not so much on power though(318 )
Old 08-15-2007, 12:24 PM
Spitfire
Thanks alot mate ! Appreciate youre opinion on that ! Another reason to install them!
Although my dads a little hesitant on installing them. He thinks there too expensive for nothing ! Don't even comment please ! He's a mechaninc but doesn't like an modifications what so ever ! (Irridium plugs are not even concidered as a mod, but he's a pure OEM person !)
But, he likes the idea of the Royal Purple !!
And about youre starter motor. I think it is most likely youre solenoid. The thingy that operates a fork/arm wich moves the starter gear forward to link it with the flywheel.
Don't know about the price though, But getting out is a bit of a b1tch !
Ever seen the GM/Cadillac Northstar 32V V-8 engine starter motor postion ? THATS A B1TCH to remove ! Its under the intake manifold and remember this is a V assembled engine.
Old 09-29-2007, 06:10 AM
nelson22's Avatar
old people=roadkill
been a while for this tread but today i checked the engine
still having the same prob
on close inspection found the wire connected to the cam shaft sensor split
wiggled it around and car did the spin but not catch symtem
put some tape round it and it worked
then started it up a few times but it went back to the same prob
will the cam shaft sensor have anything to do with the starting up of the car
Old 10-05-2007, 04:47 AM
nelson22's Avatar
old people=roadkill
still ok but still need advice on the sensor will it affect the starting of the car
Old 10-05-2007, 05:03 AM
Still here
Mein Auto: M3
Yes it will affect it mate as the timing will all be off
Edirty6 for life
Old 10-05-2007, 05:04 AM
nelson22's Avatar
old people=roadkill
cheers pal will get new sensor
Old 10-05-2007, 05:15 AM
Still here
Mein Auto: M3
I have read quite a few places that say it will not stop it starting but logic dictates that it will.
Had a mate who had a similar problem and replacing the sensor fixed it though
Edirty6 for life
