Old 01-14-2010, 08:19 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
I'm guessing something like it would work (dimensions might be different), but I don't have access to a Z4M to check. Not difficult to figure out if you already have an extinguisher and mounting parts in hand.
Originally Posted by pal View Post
Thanks Ron.
Will dwm's below style attachment mechanism also work on the Z4M seats?
Daniel
2002 M roadster
Old 01-14-2010, 11:09 PM
Ron Stygar's Avatar
19,585 Miles
Thanks Ron.
Tucked in versus the Z3. You got around 15 inches in length so might work tucked in.
If not make an adapter that sticks out like the Z3.
Behind the red extinguisher bracket is a rectangular aluminum bracket.
** screws screw the red bracket extinguisher bracket into the aluminium bracket (tapped).
* Left screw goes through both brackets to the z4 kit tab.
The right screw is under the red extinguisher bracket through the aluminum bracket to the z4 kit tab.
Old 01-15-2010, 06:22 AM
pal's Avatar
pal pal is offline
S54=Living on the Edge
Mein Auto: 2007 M Coupe, 2004 Audi T
Thanks a ton Ron and dwm. I will look and see if I can fab something up with cardboard first and try to use one of the off-the-shelf brakets that Summit Racing sells.
I need to figure out a 2lb (or larger) FE setup for the car with a quick release mechanism as its required for the Texas Mile.
Euro headers w/relocated sensors|RPI scoop|K&N panel filter|KW Clubsports w/400lb Linear Rear Springs|RE RSMs|Zeckhausen CDV|SpeedBleeders|Stoptech Brake Lines|StopTech 4-pot BBK all around|BBS RGR 18x8.5/18x10|Potenza RE-11s
Texas Mile (March, 2010): 155.4 mph
