E30 (1982 - 1993)
Old 08-18-2007, 08:41 PM
brantleyr brantleyr is offline
Mein Auto: 1986 bmw 325e
new...
just joined forums, i own a 86 325e, its all stock, will post pics sometime in future, just got done putting new paint job on it and fixing up, wondering what all i can do to get more performance out of it, pretty new to bmw's as a whole, thx
Old 08-19-2007, 01:38 PM
pics...
Old 08-19-2007, 01:46 PM
Court M3 Court M3 is offline
Mein Auto: 88 M3
source a 323i head and build a stroker. A JC chip will give you a noticeable performance boost also.
Old 08-19-2007, 01:49 PM
any good places to get these parts from, like, where do you go to when you need something?
Old 08-19-2007, 07:25 PM
omw41's Avatar
omw41 omw41 is offline
Mein Auto: 1986 BMW 325 E
Looks good. How much for the paint?
Here's three places I use:
http://www.bavauto.com/shop.asp
http://www.pelicanparts.com/BMW/tech...Jacking_Up.htm
http://www.******************.com/
Old 08-19-2007, 07:27 PM
omw41's Avatar
Oh yeah. Looks to me like your wipers are sitting a little high. You can just take them off and reattach them. They should be sitting a little above the cowling when they are "off." Also, before youdo a chip or anything like that, do a timing belt. Kepp the weight low in your car. The trunk empty and all that. Each 100 pounds of weight steals approx 10 hp.
Old 08-19-2007, 07:37 PM
yea, i know the wipers are low, been messing with them, trying to get them right, the paint ( basecoat Oxford Met. green ) was approx $250, that dosnt include primer and top coat as well as supplies ( sand paper, glazing for slight inconsistensies, other small stuff youd never even think but still adds up, luckily a relative had a hvlp we could spray it with or it would of been even more ), I appreciate the posts, how much more hp is all of this going to give me, 323i head, timing belt, new chip, and whats this stroker?
Old 08-19-2007, 07:46 PM
omw41's Avatar
A timing belt won't give you HP...but if you don't change it every 45-50K the car will make a nice statue.
Old 08-19-2007, 08:00 PM
i see, what about the other stuff?
Old 08-19-2007, 08:07 PM
omw41's Avatar
I can't help you with that. I'm the wrong guy to ask because I'm the type that likes to keep the car strictly stock. For example, when I bought it used it had a K+N setup on it, but I took it off to put a stock air box back in there. There's lots of guys here who will help ypou with that stuff. Bryce, Swiss, Matt, and a couple others come to mind. Good Luck, and welcome.
Old 08-19-2007, 08:13 PM
thx man, appreciate the comments
Old 08-19-2007, 09:02 PM
AdamAnt's Avatar
AdamAnt AdamAnt is offline
Go Fast
Send a message via MSN to AdamAnt
Mein Auto: 1986 325e
with the 323i head your car will essentially be a stroked version of the 323i, that is, with a longer stroke and gobs more torque. it will keep your 2.7l displacement, just giving it a bit more power and torque as a result of the larger intake valves and hotter cam. but of course with the head comes other things such as intake manifold, throttle body, dme.
depending on where ur from u could get away with spending about 2k and having a pretty descent little car. but thats in Australia where the euro 323i stuff is pretty common, dnt really know about availability in the US
