Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 09-25-2010, 03:19 PM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator 5-Series
Mein Auto: Trek 6500 MTB
Originally Posted by LTDUTCH View Post
That natsy windshield wiper arm nut on the drivers side is very easy to remove. NAPA is probably the ONLY tool store that carries the right size puller. Photo shows a 4 pc gear puller set, but only the smallest puller is needed. I used a 3" gear puller due to working space restrictions with hood installed. A rubber mallet was not used... only the gear puller to remove the nut and then cleaned off the spline nut post prior to reinstalling the nut.
Autozone carries a puller that fits fine: OEM 2 & 3 Jaw 2 Ton Puller (25901).
I picked one up for $35. OEM is the brand name. I used it in the 2 arm config and it worked just great.
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (97k miles)
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease transferred...no longer have)
Old 09-27-2010, 12:18 PM
Ågent99's Avatar
Moderator 5-Series
Originally Posted by Solo1 View Post
The part number is 51718159292. For some reason they hid it in the "grill diagram" in the real oem site.) The Real OEM link:
http://www.realoem.com/bmw/showparts...51&fg=20&hl=19
I replaced this item recently and regret not also getting these two items:
51 71 8 193 201 Covering LEFT
51 71 8 193 202 Covering RIGHT
These two items (#9) exist at either end of the above Windshield Frame Cover (#3) and basically started crumbling on me as I messed with them a tad to work the windshield frame cover on. They appear that they would be easy to install but I don't know for sure. They are made of the same rubbery material as the Windshield Cover that goes around three sides of the windshield...the one that has its own stuck thread that I started.
