E36 (1991 - 1999)
Old 08-22-2007, 05:28 PM
AlkalineOm3n AlkalineOm3n is offline
Mein Auto: Nothing ATM
Door Panel Delamination
Has anyone ever found a solution besides going to the dealer to fix the door panel delamination?
Old 08-22-2007, 05:34 PM
greenbeem's Avatar
greenbeem greenbeem is offline
Do I Offend?
Send a message via Yahoo to greenbeem
Mein Auto: 1994 318iC
EPOXY! my friend. If you're refering to the plastic pieces that are attached to the door panel, epoxy works great. just make sure you clean the old glue off or it wont stick. also if you can , make some sandbags out of large ziploc bags to keep everthing in place while the glue sets. And use something like a 15 or 30 min. epoxy.
Old 08-22-2007, 10:30 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
True, but that requires pulling the material off and disassembling a bit, no?
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 08-23-2007, 02:55 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
This any help? - http://www.bmwe36blog.com/2007/03/28...36-door-panel/
2001 Mini Cooper R50
Edirty6 for life
Old 08-23-2007, 06:43 AM
SCANDINAVIAN13 SCANDINAVIAN13 is offline
Resident Pilot
Mein Auto: BMW Not Found
If you're talking about the panel just sagging and coming off of the door, the post from Pirate will help you.
If you're talking about the vinyl coming off of the panel itself, I might be able to help once I finish my own repair and DIY (yes, it's still coming along - takes a while).
Kyle
1993 325is - Frigg - Grounded
2001 Z3 2.5 - Iğunn - Active
Old 08-24-2007, 07:04 AM
DNRC's Avatar
DNRC DNRC is offline
Life finds a way
Mein Auto: 2000 Subaru Legacy GT
my vinyl is coming off right now and it seems to be getting a lot worse everyday because of the 100+ weather here in GA. would epoxy be able to fix that?
John 3:16
Originally Posted by youraveragepunt View Post
blimey looks like me shelia has done a right number on this one....
Old 08-24-2007, 08:45 AM
Resident Pilot
I'd use Gorilla glue.
Epoxy holds amazingly, but it's really tough to get right and it's extremely rigid.
Kyle
Old 08-24-2007, 09:08 AM
DNRC's Avatar
Life finds a way
for the vinyl?
John 3:16
Old 08-24-2007, 09:25 AM
greenbeem's Avatar
Do I Offend?
For the vinyl contact cement works great. The only problem I had with the vinyl was that it had shrunk along with coming off and it makes it hard to get it to stay in place in areas like the door pockets,where it has to rap around the edge of the cardboard panel. Just make sure you clean it really well with acetone and let it dry completely before gluing.
She's good, but I keep finding Barbie doll's under the hood.
Old 08-27-2007, 08:26 AM
Resident Pilot
This is how I'm doing it:
I have to heat it as I'm having the same shrinking problem mentioned above by greenbeem, so I'm using a hair dryer on high heat. Once it's hot, I stretch it. Then, while holding it stretched and taught, I drip Gorilla glue (not too much! the glue expands!) down where the vinyl will contact the panel, then fold it over and clamp it using ratchet-type clamps.
Kyle
Old 08-27-2007, 02:29 PM
greenbeem's Avatar
Do I Offend?
Nice
Old 08-27-2007, 03:22 PM
VTi's Avatar
VTi VTi is offline
Dale Crane is the MAN!
Send a message via AIM to VTi
Mein Auto: 95 320i / 00 520i
Heh, just picked up a set of yellow versions of those!
The small ones are EXTREMELY handy for a brake pad job
Old 08-27-2007, 06:54 PM
Resident Pilot
I need to do my pads soon...
This door thing is killer. It's not so hard as it is tedious and irritating, which is why it's taking so long for me.
Kyle
