E30 (1982 - 1993)
Old 08-29-2007, 07:43 AM
jetter2's Avatar
jetter2 jetter2 is offline
insert something witty...
Send a message via AIM to jetter2
Mein Auto: 05 ZHP CPE
"Check Engine" light comes on..
The E30 runs great...although sometimes the "Check Engine" red light on the dash will come on for one or two seconds and then just go off.
Is this a bad sensor? Any ideas what is causing it? The car runs and drives great, all fluids are checked and changed as required etc...
I just don't want something to sneak up and bit me in the ass. The M20 is a great motor and hasn't given me any issues yet....
Old 08-29-2007, 09:14 AM
AndrewZ's Avatar
AndrewZ AndrewZ is offline
Super Moderator
Mein Auto: 91 E30
That use to happen to my 318. All I did was disconnect the negative cable for about 15 seconds, then reconnect. The problem went away for me. Not sure what cause it though.
Old 08-29-2007, 03:06 PM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
You've been around long enough to know to search first.
There are like 6 codes your Motronic will spit out. Could there be a pedal trick for your car?
Search.
Old 08-29-2007, 03:07 PM
Banned
Mein Auto:
Even better advice. The 318 uses a different EM, L-Jetronic. It spits like 4 codes. Real complicated.
Old 08-29-2007, 03:32 PM
Banned
Mein Auto:
Screw it, you owe me Jetter.
http://www.bimmerfest.com/forums/sho...ht=pedal+trick
http://www.bimmerfest.com/forums/sho...t=engine+codes
Old 08-29-2007, 10:01 PM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
He should let you borrow his Aston and bang his nympho centerfold GF.
Old 09-02-2007, 03:25 PM
John L. Harrell John L. Harrell is offline
John Harrell
Mein Auto: 87 325i / 98 528i
Try tapping on the face of the instrument cluster.
If it comes on /off most likely poor contacts on the
si board and plugs.
A little Wd 40 will do ya right.
O2 sensor on the way out will present itself the same way you describe. May take many many months to get to the point of hard failure. Unless you have access to a fault code reader you really are just guessing.
Old 09-02-2007, 07:34 PM
KottonMouthKing KottonMouthKing is offline
Mein Auto: '88 325is
i did that same thing when i had a dashboard full of flashing lights even though there was nothing wrong with it and it fixed them all
