Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 08-26-2007, 05:51 AM
Court M3 Court M3 is offline
Mein Auto: 88 M3
overhead panel coolant light
Mine has been on for awhile now, but temp gauge reads fine. Any ideas what could cause this? Thinking maybe cap on resevoir
Old 08-26-2007, 07:20 AM
Its13oclock Its13oclock is offline
Mein Auto: '89 325is
That happened to me before as well, and it turned out that the sensor in the coolant tank was broken.
E60 530i
Mods: 35% Tint All Around
Eventual (aka Lottery) Mods: LED Angel Eyes, LED Fogs, RPi Scoop, M Tech Front Bumper, Hamman Front Lip, VMR V710 Wheels
E30 325is
Retired...
Old 08-26-2007, 07:27 AM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
+1 a pretty common problem as I understand it.
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
Old 08-26-2007, 09:26 AM
Mein Auto: 88 M3
Ok going to check it out this afternoon. Will a late model sendsor work just as well?
Old 08-26-2007, 02:50 PM
omw41's Avatar
omw41 omw41 is offline
Mein Auto: 1986 BMW 325 E
it should...but you may have to splice the connector. This is a real common issue and the part sells on Ebay for around 15.00.
Old 08-27-2007, 08:38 AM
rbn14 rbn14 is offline
Mein Auto: 2001 Powerstroke 350
I would test the sensor first. Just pull it out put an ohm meter on it and see it the circuit closes . I thought mine was bad but it was the connector.
Old 08-27-2007, 08:49 AM
danielw05 danielw05 is offline
Send a message via AIM to danielw05 Send a message via MSN to danielw05 Send a message via Yahoo to danielw05 Send a message via Skype™ to danielw05
Mein Auto: 1990 325i
I cleaned the connections and now mine works just fine.
Old 08-27-2007, 11:07 AM
omw41's Avatar
Yeah...that too.
Old 08-27-2007, 02:21 PM
Spunkye30nOk Spunkye30nOk is offline
e30 lover
Mein Auto: e30 325is
if you haven't replaced the sensor just replace its like 36 bucks from the dealership. When my light started coming on *even though it was full of coolant* it was the sensor in the coolant tank. Pulled mine out and the white looking piece at the bottom of the sensor was pretty much dark brown *fluid was green though* I figured it was probably the original sensor.
Old 09-02-2007, 02:33 PM
John L. Harrell John L. Harrell is offline
John Harrell
Mein Auto: 87 325i / 98 528i
The sensor is a fluid level sensor. It does not have anything to do with temperature.
Roger on the ohms check for good/bad.
Wires do break as it is in a location that gets bumped/disturbed.
Old 09-02-2007, 07:50 PM
omw41's Avatar
I thought he said temp gauge was fine????
