6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations. |
#126
Current cars 2008 650i Convertible full tint, 22' wheels magnoflow 2007 Range Rover HSE supercharged Past Cars/Glory Days 02 lambo Murcielago 06 Bentley CGT 06 Merc CLS 550 07 Ferrari F430 06 Ferrari F430 Spider 06 Lambo Gallardo 05 Lambo Gallardo 04 Ferrari 360 Challenge Stradale 01 Ferrari 360 spider 05 Audi S6 02 Porsche targa S 99 Ferrari 360 91 Ferrari 348TS 99 Hummer H1 soft top |
#127
That sounds like a battery issue? I would trickle charge or have the battery tested. I assume you are not putting the top up with the remote? If so it takes the life out of your battery
Thanks for reply. I always use the trickle charge to keep maintaning the battery. Also I always to open or close the top with engine running to not drain out the battery. When I do the test, I still left the tickle charge to give additional power while the key inigtion on |
#128
weird these tops and electronics fopr them. So many moving parts and peices communicating with others thigns are bound to go wrong. I unfortuantely suggest a dealer visit to plug in and read the code to track the issue
#129
2013 X5M 2009 135i Coupe 2012 550i 2008 650i Convertible- Sold 2007 550i- Sold 2006 750i- Sold 2004 545i- Returned/Lemon Law 2001 330ci- Sold |
#130
Hi,
Boesman10's solution to the top lock alarm just worked for me. I have had my 650i since February. It is a 2007 and I experienced the top lock alarm approximately 2 months ago and I took it into the dealer to fix it because my windows were locked half open and the trunk would not open. It cost me a little over $500.00 because the dealer stated that the extended warranty did not cover my top. Yesterday my car experienced the same top lock alarm and after reading Boesman10's solution, I tried it. It worked like a dream. No problems since. Thank You! DEDroptop |
#131
Good afternoon: Boesman10 is a genius and a savior. I have an 05 645 that I drive sparingly since new (35,000 miles now --- another set of issues, regarding battery, from insufficient driving, but that's a different story) that in the last 3 weeks have begun to exhibit the dreaded "top not locked" syndrome --- which I had never heard of til today, which I learned of only when I started to read through this thread --- the flashing red, locked trunk, inability to open or close; I had actually called BMW service to schedule an appointment and asked to speak to the shop foreman and was waiting for a call back. Of course, I am out of warranty. I literally jumped with excitement when I read Boeman10's post and hopes elevated when I saw that his solution worked for DEDroptop. I ran out to the garage not knowing exactly what to do and tried pushing a few of the joints with apparently no change in the flashing red light, feeling very disappointed. I tried running my fingers along the driver's side bar, making sure to touch base with every point, and lo and behold, the light disappeared! Sure enough, not daring to touch the top open/close button, I got out to check the trunk fob and it opened! So, I've decided to forego the dealer appointment, knowing that I at least have a response to the issue that I can live with.
So, kudos to Boesman10, for cutting through this; and thank you!! |
#132
A perissodactyl ungulate may be propelled toward a body of aqueous fluid, but such ungulate cannot be compelled or forcibly induced to imbibe such fluid. |
#133
Tstranger27 I can't believe all that! Well, actually I can haha. Such madness!!! I experienced this problem twice last month before the dealer "fixed it" and I was picturing exactly what you described... A bunch of us speeding around in our nearly six figure cars avoiding rain and thunderstorms and parking under overpasses. What a joke! Wish we could make some sort of film and send it to BMW engineers. Such an embarrassment... I'm dreading the day a cold front comes through and my windows randomly go down on the highway.
#134
Hi ,
I used the software that I bought $275 from Bavarian Technic to read code and clear fault code for the sensor halt left top lock (red light blink) then later it showed at Convertible column as A6A7 "Energy Saving Mode Active" that might cause my soft top not to closing down (half way) since then. I asked Technician of Bavarian what code means but he refused to give me any answer . I suggest that better don't buy it or cable because might cause your BMW system go wrong and you might won't have any answer for that caused. |
#135
Since Bavarian Technic does not generate the codes (BMW does) their documentation states that codes displayed are the same as the factory tool (DIS/GT1) and to refer to BMW factory documentation for more info. I could not find much info on "Energy Saving Mode Active" but it looks like that error can occur for several different modules in the car.
Straight lines are for fast cars...turns are for fast drivers '04 M3 - track '06 650i Cab - daily driver '02 Highlander - kid hauler '01 330Ci - winter beater
#136
Thanks Yorgi for those information. I hoped that I could find what the code mean and share with everyone this problem.
#137
The bar rub fix needs to be added to the stickys
This is the best fix ever! Great thinking to search for the sensor and discovering a solution for the dreaded red light!
#138
Pulling my hair out!!!
I found this site to help w this SAME problem!!!......only to find out there are LOTS of u apparently pulling ur hair out too!!! I just started to hav all these conv top problems this week....over & over!!!! So , my fiancé called our local dealership, who informed him (get this!) - that there r 2 decals in the trunk that can never have anything covering them!!!! Well, after practically undoing the entire trunk.....there r no such decals (in MY trunk anyway!) & nothing is in there anyway!!!
I just (2 mos ago) traded in a Mercedes SL500 conv (that had conv top problems too!) for my 1st Beamer.......& sadly.....I'm not a happy customer so far. This is a ridiculous problem for this same car to be having w SO many of us & BMW not able to adequately repair it - in a timely manner!!!!! ![]()
#139
As I peruse other forums debating what the next car I may get will be it strikes me that high-end cars in general have a ton of problems that you would not expect. Quality issues are not exclusive to Mercedes...BMW and others seem to have their share of issues also. Sorry, wish I could tell you that you bought a car that would be trouble free, it still may be the case after you get through this but you would be in the minority. |
#140
Cai Tai,
I think the "saving energy mode" is when your battery is getting old or weak. The BMWs and Mini Coopers both do the same thing. When the battery is older and the car is parked, it will start turning off anything that causes battery drain to ensure there is enough juice to start the car. For example, it will drop things like radio stations, MPG, TPS sensor data, etc. Both the wife's 2007 Mini Cooper S and my 2007 BMW 650i have done this before and the service advisor told me that the code showing was "saving energy mode" (or very similar to this - paperwork is at home right now). Were you trying to close the top when the car was not running? Good luck. |
#141
Thanks Kansas Corey,
Your information might help me . I close my top with engine running |
#142
I replaced a new battery but the A6A7 "saving energy mode active" fault code still be there. It might cause my soft top close only half way. Please give me an advice
thanks |
#143
If you are still getting the "energy saving mode" error after a new battery I would check the alternator and check if something is putting a draw on the battery when the car is shut off.
#144
i took mine back
I was so tired of taking it back to the dealer over and over again for that top down problem.
#145
I just had this problem and this fix {pressure on the joint in the roof} worked like a treat. Thank you so much boesman10 !!!
#146
boesman10,
Thank you so much for your post (Boesman10 #120). I have been searching for a solution to this problem for weeks now. I followed your directions (photos) and pressed the sensor located on the drivers side, rear back panel conv.'s top as indicated. IT WORKS! Congratulations for finding this. Amazing!!!! |
#147
I had my car in while under factory warranty for the top unlock problem, after that it still popped up then went away for the last year.
Once again, it has manifested this week. Unfortunately it was when my Wife got in the car to come home from work, I was out of town and got the call "what is wrong with the car". For you married guys you know the routine, it was completely my fault! Luckily during her drive home with the windows half down the error went away on it's own. Perhaps the jostling of the drive righted my sensor or cable? I checked the car this morning and it was giving the error, I did the "boesman10" push and it went away. I need to teach the Wifey this routine so that she is prepared next time. Still irritating that we have to worry about using the convertible top! For me it is happening because it got cooler out!!! |
#148
The "boesman10" Push
TO: TampaMark, chickapea1, dunkirk, RossArmstrong, castercorey, elan72, DEDrop, WineCountry and others...
It's a rainy day in Tampa, FL and I had to use the "boesman10" push (thanks to tampamark for giving the "move" a name) this afternoon, saving me once again from driving with windows down in the rain...so I figured let me log on to see if there were any replies to my original post (have been out of touch for a while)...and great was my surprise to see how many people found value in the post! I'm really thrilled that this "band-aid" is indeed working for others as well. It's sad to say, but I'm using this method almost once a week. Such a nice car with such a basic flaw. I'm so good at it now that I can even do the "boesman10" push while driving (DISCLOSURE: I DO NOT RECOMMEND ANYONE DOING THIS). Even my kids (when sitting in the back) are familiar with the maneuver - they have it down to a science. They are even fighting to get the seat closest to the "boesman10" rub point when getting in the car (at ages 6 and 10 they like to turn off the "red blinking light that causes daddy to use inappropriate words"). Sad to say, but I'll probably pass this on to whomever buys my car one day since I refuse to spend money to get this fixed. Regards, --boesman10 Last edited by boesman10; 11-28-2011 at 03:49 PM. Reason: adding a reference, fixing typo |
#149
![]() Thanks again for finding this simple fix to a big problem.
#150
Awesome post boesman. Even if you paid to have it fixed it does not ensure it will stick!!!
Thanks again. Sent from my SCH-I510 using Bimmer |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
