E36 (1991 - 1999)
Old 08-26-2007, 04:19 PM
abram_quito abram_quito is offline
Banned
Mein Auto: 97 BMW 328i E36 sedan
97 BMW 328i E36 sedan steering wheel squealing and turning difficulties
i have this car
when i make turns the steering wheel does not move to the center
as all cars are suppose to
like when making a typical left turn the steering gradually moves to the center freely to
keep the wheels straight
what is the problem?
and when at neutral i hear squeals inside the car
what is problem?
Old 08-26-2007, 04:30 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Hey, welcome to the fest
Are your tyre pressures ok?
2001 Mini Cooper R50
Edirty6 for life
Old 08-26-2007, 09:59 PM
Ronnaferd's Avatar
Ronnaferd Ronnaferd is offline
328i for life
Send a message via AIM to Ronnaferd Send a message via MSN to Ronnaferd
Mein Auto: 97 328i sport pkg
I would have to bet something is wrong with the power steering. The road should help pull the wheels back to straight if all is working right.
Old 08-28-2007, 03:38 PM
Banned
this happened a day before i driven it
and the following day
the steering went on to the left as i typically do
but had to steer hard as hell to turn back to center
Old 08-28-2007, 03:39 PM
Banned
can not be power steering
do squealing in engine bay
or tiny squeals inside steering wheel column covers
Old 08-28-2007, 03:43 PM
bounzing_soulz's Avatar
bounzing_soulz bounzing_soulz is offline
Mein Auto: 1996 bmw 328is
wait im confused... is the sound coming from the engine bay? or the steering wheel covers?
engine bay... prolly power stearing. Stearing wheel, get a shop to lube up the wheel or stearing collumn, they will know which one. Mine did that for a little bit, but it was nothing like the way you described it. It just made a slight squeel, I didnt notice a differance in performance as stearing is concerned though.
1996 BMW 328is 5spd
Photo Sharing and Video Hosting at Photobucket
Clarion Head Unit : Sirius Satelite Radio : K&N Cold Air Intake : Carr Industries Short Shifter
Dinan Stage II Software : 10w 30 Royal Purple : Zimmerman Rotors : Hawk Performance Pads : Staggard M3 Wheels
Still here
Mein Auto: M3
These may help - http://www.bimmerfest.com/forums/sho...75#post2605775
Edirty6 for life
Old 08-28-2007, 05:05 PM
Talon328's Avatar
Talon328 Talon328 is offline
Mein Auto: '08 135i
I have a squeaky wheel with a little steering play.
1) it looks like the squeak is not DIY. Not worth it?
2) Steering play, I'm guessing, is not DIY.
Old 08-29-2007, 04:47 PM
Banned
Help Power Steering Problems
small squeals
noises in steering column covers when making turns
engine compartment is quiet
buy does not turn with ease
this is the symtom
i make a turn on a intersection
when i make that turn
the steering wheel does not move back to the center and the front wheels do not get
straight
i have to force the steering wheel
back to the center
what is the problem
ps level is okay to MAX
could there be air in PS pump
or what
help me
Old 08-29-2007, 10:01 PM
Conehead Conehead is offline
Go you Good Thing
Mein Auto: e36 316I M
Originally Posted by abram_quito View Post
small squeals
this is the symtom
straight
back to the center
what is the problem
or what
help me
After reading this post and a looking at the resonses, I am with Pirate on this one. Check the tire Pressure.
It should be anywhere from 28-40PSI, depending on what size tires and wheels you are running.
The noise in the steering wheel is the rear cover of the wheel rubbing on the steering colum. Mine also does this and I would doubt it has anything to do with your problem.
Try this first before you replace anything else.
The second thing to try, after checking the tires, is a wheel alinment.
Cone
XXX
The best predictor for future behaviour, is past behaviour. ALSO, IT SHOULD BE NOTED:......AMATURES BUILT THE ARK..AND PROFESSIONALS BUILT THE TITANIC..................QUOTE FOR THE DAY.. Good drivers know how to get out of trouble, and better drivers know how to avoid it.....The Cone 2006 & 2007
