E36 (1991 - 1999)
Old 08-27-2007, 01:00 PM
kyle2blue's Avatar
kyle2blue kyle2blue is offline
Mein Auto: 94' 325is
help!
Anyways, this past sunday my radiator decided that it was time to depart. so, I'm looking for a new one. What's a good brand? I was leaning toward get a Behr. Any suggestions
Old 08-27-2007, 01:18 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
OEM are good buddy
I use one from an E36 328i with A/C as it is bigger (apparently)
2001 Mini Cooper R50
Edirty6 for life
Old 08-27-2007, 01:20 PM
kyle2blue's Avatar
thanks, would I have to worry about it breaking again?
Old 08-27-2007, 01:22 PM
Still here
Mein Auto: M3
In theory...no mate
Change your waterpump for one with metal impellers (if you have not already) while you have all that stuff out and it should all be good
Edirty6 for life
Old 08-27-2007, 03:20 PM
PhilipWOT's Avatar
PhilipWOT PhilipWOT is offline
Turn Burglar
Location: Atl: Come for the pollution, stay for the traffic
Mein Auto: Red Assless Chaps
Unless you're turbo charging or driving across the desert in the Dakar Rally the OEM replacement will be fine.
Old 08-27-2007, 03:22 PM
VTi's Avatar
VTi VTi is offline
Dale Crane is the MAN!
Send a message via AIM to VTi
Mein Auto: 95 320i / 00 520i
fo sho
Old 08-27-2007, 03:31 PM
rwg rwg is offline
Mein Auto: '14 A4
Except the metal impellers wear out too. There is a composite impeller that came about after the metal impeller that supposedly is the one to get.
So it went plastic, metal, plastic and one of the plastics is desirable. Clear as mud, isn't it? (I just went with metal last time I changed one - I knew it had a decent, if not indefinite, lifespan).
Old 08-27-2007, 03:34 PM
PhilipWOT's Avatar
Turn Burglar
I can personally vouch for the sh!ttiness of the first plastic impeller water pumps. I was lucky enough to have mine disassemble itself, along with the outer water pump housing on my way home from the dealership where i bought the car. No kidding, if you search far enough back you can proably find the thread i made about it.
I replaced it with one of the updated plastic ones and haven't had a problem since, some 25,XXX miles later.
Old 08-27-2007, 03:41 PM
Still here
Mein Auto: M3
That sucks!!
I got a third party metal one which seems very good (though difficult to tell hehehe)
Edirty6 for life
Old 08-27-2007, 05:44 PM
rwg rwg is offline
Mein Auto: '14 A4
Well I think even the disintegrating plastic ones had a 40k mile life expectancy. It's just not something you want to have go out. It's espeically not something you want to have fail and not notice your temp gauge.
Old 08-27-2007, 09:40 PM
kyle2blue's Avatar
Well it's done... 1 hour later.... lol. But after I changed it, I think there was a air bubble in it, from when the hose broke. So that took a while to work out... So now I have completely changed my entire cooling system. aluminum thermostat housing, thermostat, Hoses, stewart high performance waterpump.... and now the radiator. Hopefully no more problems. except for the squeaky steering wheel.? anyone know why that is?
Old 08-28-2007, 02:32 AM
Still here
Mein Auto: M3
I had to do the same mate....
Edirty6 for life
Old 08-28-2007, 02:45 AM
Bmwcat Bmwcat is offline
Retired Slacker
Mein Auto: A car.
I just did mine with a Behr replacement. They last 100k miles, so you may sell the car before needing a new one.
"Patriotism is the last refuge of a scoundrel." -Samuel Johnson
Old 08-28-2007, 10:34 AM
rwg rwg is offline
Mein Auto: '14 A4
Squeaky steering wheel is a common problem. Iirc, it is either an easy fix with some lube or a real pita fix that requires taking stuff apart and replacing parts, depending on why your wheel is squeaking. A search should turn up some direct instructions.
Old 08-28-2007, 11:31 AM
suntex01 suntex01 is offline
Mein Auto: 328is
well ive heard most of the time its airbag contact ring go bad...
im going to change it once other more important things are done.
Old 08-28-2007, 11:49 AM
Still here
Mein Auto: M3
Try these -
http://forums.bimmerforums.com/forum...d.php?t=245961
http://www.pelicanparts.com/bmw/tech...t/E36-Tilt.htm (read the second paragraph)
Edirty6 for life
