Old 08-29-2013, 06:56 PM
scottjoh scottjoh is offline
Mein Auto: 1999 323i
Odd electrical problems (turn signal, dash backlight, hazard switch)
Originally Posted by stlsinger View Post
I have the exact same issues. Took it to the dealer today. They said they were getting crazy readings from the general module. So to fix they want to replace it. 500+ for the part the 3 hours labor. I thought this was easy to replace. Not 3 hours. They even said it was behind the cluster? I read it's behind the glove box. Any one resolve this issue successfully yet?
You say you EXACTLY the same problems (as dkrieg), is that correct?
Originally Posted by dkrieg View Post
The complete list of items that stop working are: turn signals, hazard button, daytime lights come on (light switch doesn't activate them), fog lights, backlight for dash, ashtray light, seatbelt idiot light (does not even light during the initial ignition test but other airbag, etc do during initial test). I think that is the complete list.
Because dkrieg's problems would be very difficult for those problems to be caused by the general module. If those problems were caused by the general module, simply disconnecting the module should correct all the problems.
Old 08-29-2013, 07:11 PM
stlsinger stlsinger is offline
Mein Auto: 528i
You're right. As far as what I've read from the forums. Yes. If I disconnect the gm my alarm goes off. I ordered a used gm from the same year same series car as mine. Going to an Indy shop here in st. Louis next Thursday. I'm gonna try and plug it in when I get it anyways
Old 08-29-2013, 07:33 PM
Don't worry about the alarm siren. It'll shut off in about 30 seconds and won't get tripped again! Just unplug the module and see if it helps cure your problems. If it doesn't help then the general module is not the problem.
Old 08-29-2013, 07:49 PM
Mein Auto: 528i
I would think if I disconnected it nothing would work
Old 08-29-2013, 09:59 PM
If you disconnect the general module only the rear door locks, rear windows, wipers, interior dome lights, key fob remote functions, trunk release, gear shift light, luggage compartment lights and a few other items won't work. Basically the general module is not responsible or any of the problems you and the OP are having except maybe the ashtray light. The ashtray light might be on the VA1 line from the general module.
Old 09-23-2013, 06:33 PM
riverjamie riverjamie is offline
Mein Auto: 528i
Has anyone solved this problem yet?
I have 2000 528i, sometimes when opening the car with the remote key the flashers with flash, no alarm, the car will start but no turn signals. I just lock the car with the remote key and unlock it again and everything is back to normal??
Old 04-21-2014, 09:40 PM
dvtechservice dvtechservice is offline
Mein Auto: 2012 X3 28
2000 323i Sedan
I had the following electrical problem
- blinkers work outside, but not in dash
- hazards work outside, but not in dash
- high-beam light work, but indicator in dash does not work
- seat belt light does not turn off
- air conditioning does not work
- door/trunk open indicator on dash does not work
I did a cluster test02, and the cluster lights-up perfectly. I did the the ignition switch check by opening and closing the passenger vanity mirror with no difference in problem. I scanned the car with bmwscanner 1.4 and 4-5 different modules did not read.
I fixed the problem by disconnecting the negative battery terminal for 30 minutes. Connected it back, and started the car, problem is now gone. All dash indicators work and seat-belt light turns-off.
I hope this helps someone.
Old 04-13-2016, 08:59 PM
v8madness v8madness is offline
Mein Auto: 540i
dashboard lights
hi my indicators still work but doesnt show up on dashboard and at the same time the radio light aint working nothing showing at all not even the time i think where the digital ks show well thats got the same problem to checked all fuses they seem to b fine but will google what bmw blown fuses look like
Old 04-13-2016, 09:00 PM
Mein Auto: 540i
dashboard lights
hi my indicators still work but doesnt show up on dashboard and at the same time the radio light aint working nothing showing at all not even the time i think where the digital ks show well thats got the same problem to checked all fuses they seem to b fine but will google what bmw blown fuses look like i run a 540i E39
Old 04-14-2016, 12:52 PM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
Feel free to ignore this advice, but as a rule, the easier you make it for others to understand your posts, the more responses you'll get. Omitting periods and posting a confusing stream of words makes it feel like too much work for some of us to figure out what you're saying.
BMW--giving new meaning to the phrase "disposable income."
Old 11-21-2016, 10:43 AM
andloz97 andloz97 is offline
Mein Auto: e39 2002 525i
After my car sat for two months due to overheating/coolant pump issues, my Turn signals, Back-up lights, Hazards, Interior dash, fog lights, Halos Rings, and high beams would not work. The exterior lighting system only provided low beams and the brake lights, along with the rear celis leds. I read through this thread and realized that i had resistors set up for my led turn signal bulbs. Those connections were exposed to water(rain) and so I figured I had a short. I removed my tail lights completely, drained them and dried all light bulb sockets, then removed the led bulbs and resistors, and placed the original amber halogen bulbs and now everything works, except for the reverse/back-up lights. Does anyone know what could be the problem?
Old 02-24-2017, 10:26 PM
Zenski Zenski is offline
Mein Auto: 2005 BMW Z4
Pretty sure I have a short in mine. Had left the top down during a rain storm. Currently having the same problems others are with dash lights, except my headlights aren't working at all.
Any fixes for the dash? Other than replacing the ignition switch and disconnecting the negative battery terminal?
Old 02-25-2017, 08:48 AM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
the dash lighting, headlights and all other external lights are controlled by the LKM, which is in the passenger footwell. is the carpet wet there?
99 528i 5sp sport
Old 02-25-2017, 06:50 PM
Look into the k-bus. When the k-bus is down you should also have problems with the AC compressor not turning on. Unfortunately, k-bus problems can be very difficult to track down if you are not methodical.
Old 02-26-2017, 07:39 AM
mattmar1's Avatar
Wingnut
might need to look under the passenger seat at the electrical connection box if the carpet got wet
99 528i 5sp sport
