Old 08-29-2007, 09:36 AM
ajfinoak ajfinoak is offline
Mein Auto: '06 BMW 325i '01 Acura CL
Speedometer Calibration
I was reading the long term review of the '06 330 in Car and Driver last month and it said that the speedometer is over by 4 mph. Anyone else think (or know) if theirs is off? On SF Bay Area highways, I seem to be passing a lot more people at 80 mph in my Acura than at 80 in the BMW. How can one check?
Old 08-29-2007, 09:39 AM
BMW Power's Avatar
BMW Power BMW Power is offline
Mein Auto: 2012 X5 35d
You can use a portable GPS and look at the speed there. BMW speedometers are optimistic, it gets worse with higher speed. There has been some discussion of this before.
2014 i3 Rex
Retired 2012 X5 35d DSB - Prem, SAV, Cold, Sound, Tech packages, Apps Delivered 6/6/12
Retired 2011 335d AW, M Sport, Premium and Convenience pkg, Heated Seats, Nav, HK, iPod/USB, smart phone. ED 8/31/10
Retired 2008 335i Coupe 6-speed Manual, Montego Blue, Sport, Premium, CW, Nav, PDC, AS, Shade, HD, Sat, Ipod/USB, Logic 7, CA
PCD 11/07
Retired 2004 545i Sapphire Black/Black 6-speed Manual, Sport.
Old 08-29-2007, 10:02 AM
Sorry- just did a search and realized it is just something that needs to be accepted about the car. Maybe I will save myself from a ticket while deluding myself that I am speeding.
Old 08-29-2007, 03:38 PM
VIZSLA's Avatar
VIZSLA VIZSLA is offline
Mein Auto: 328 328 308
GPS units do not have sufficient accuracy (the margin of error is at best twenty feet and can be well over one hundred) to use as a speedometer. Useing mile markers and a stop watch is about the best measure. At sixty mph you'll pass one mile every sixty seconds. Any decent stop watch will have a tachymeter in the bezel to do the math for you.
Old 08-29-2007, 04:08 PM
bufasion bufasion is offline
Mein Auto: 328xi
Originally Posted by VIZSLA View Post
GPS units do not have sufficient accuracy (the margin of error is at best twenty feet and can be well over one hundred) to use as a speedometer...
Typical GPS units use more than just position data to calculate speed. The spec for velocity error on Nuvi is 0.05m/s RMS, which translates to about 0.11 mph.
http://gpsinformation.net/main/gpsspeed.htm
Old 08-29-2007, 04:10 PM
Tanning machine's Avatar
Tanning machine Tanning machine is offline
Using SPF 45
Mein Auto: 2004 330Cic
This is good (no idea on GPS). I've done it before, and my BMW seems to be about 7% over the actual speed. That's way more than any other car I've driven.
Tanning Machine I: 1989 325iC (Salmon Silver/Black, Heated Seats, LSD). 7/26/1989-11/1/2003.
Tanning Machine II: 2004 330Cic (Silver Gray/Natural Brown, SP, PP, Heated Seats, Xenons). 8/29/2003-present.
Old 08-29-2007, 04:14 PM
VIZSLA's Avatar
Originally Posted by bufasion View Post
GPS units usually use more than just position data to calculate speed. The spec for velocity error on Nuvi is 0.05m/s RMS, which translates to about 0.11 mph.
What data beside change of position over time can yield speed? If position starts as an aproximate any resulting calculation will have the same aproximation in its result. The Nuvi stats sound like they relate to processing accuracy not positional.
Old 08-29-2007, 05:41 PM
Mein Auto: 328xi
Doppler shift. See http://gpsinformation.net/main/gpsspeed.htm
From the NAVSTAR GPS User Equipment Introduction document Section 3.7:
GPS receivers typically calculate velocity by measuring the frequency shift (Doppler shift) of the GPS D-band carrier(s). Velocity accuracy can be scenario dependent, (multipath, obstructed sky view from the dash of a car, mountains, city canyons, bad DOP) but 0.2 m/sec per axis (95%) is achievable for PPS and SPS velocity accuracy is the same as PPS when SA is off.
Velocity measured by a GPS is inherently 3 dimension, but consumer GPS receivers only report 2D (horizontal) speed on their readout. Garmin's specifications quote 0.1mph accuracy but due to signal degredation problems noted above, perhaps 0.5mph accuracy in typical automobile applications would be what you can count on....
Old 08-29-2007, 06:07 PM
VIZSLA's Avatar
Thanks for the backround. Hadn't occured to me that that Herr Dopler would be involved.
As an aside the Garmin will register higher speeds than the article indicated. My Max speed is 611 MPH. Done not in a BMW but a Boeing.
Old 08-29-2007, 06:14 PM
BMW Power's Avatar
I have also used the "Your Speed is" radar signs the local police put up.
2014 i3 Rex
PCD 11/07
Old 08-29-2007, 06:20 PM
crowz's Avatar
crowz crowz is offline
Mein Auto: '00 323i/97 528i/94 318is
Thats pretty accurate though as far as car speedometers go. So Id take the gps as the best way to determine how accurate the speedometer is.
Old 08-29-2007, 06:32 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
While not definitive by any means, you can also use the car`s OBC.... put it in the AVG. MPH function, and on a clear stretch of highway, set your cruise control exactly on a speedo-indicated 60 mph. Then zero out the OBC while on the cruise control, and compare the speedo`s reading to the OBC reading. Of course, the farther you drive, the more accurate your average reading will become. You can increase your speed in 10 MPH increments to see if the error rate increases with rate of speed.
Regards,
Bob
Old 08-29-2007, 06:40 PM
Ruff Rider's Avatar
Ruff Rider Ruff Rider is offline
Mein Auto: A bicycle
Just lick your finger. Stick it out the window. If it dries in 3 seconds your going 62mph. Works 60% of the time every time.
[SIGPIC][/SIGPIC]
Old 08-29-2007, 06:54 PM
Mein Auto: 328xi
I think most GPS has a limit at 999 mph. My max ground speed is 185 mph, not in a BMW but in a train. Max speed in my 328xi is only 129 mph (4600 rpm in 6th or 5900 in 5th). The speedo indicated 136 mph.
Old 08-30-2007, 02:38 AM
Briar Briar is offline
Mein Auto: 335i. 996 Cab
I have tested my 335I versus a garmin and the 335i is consistently indicating 3 mph over the garmin, from 30 - 90 mph. Error is less below 30 mph, but not able to quatify.
Comparing distance traveled is less than 1%, for trips over 30 miles.
Old 08-30-2007, 09:37 AM
BMW Power's Avatar
The odometers are supposed to be acurate, otherwise warranty would run out early. Honda just extended their warranty mileage by 5% because the odometers were off on certain vehicles.
2014 i3 Rex
PCD 11/07
Old 08-30-2007, 11:11 AM
AzNMpower32's Avatar
Tar Heel Faithful
I believe deep inside the computer system, the BMW knows the true speed. However, the speedometer is a fraction off. I read somewhere that for almost any analog speedometer, the error gets worse as speeds increase. The X3 is about 3% off.
jwac's Avatar
jwac jwac is offline
Mein Auto: '14 335i 6MT
I've heard about this BMW phenomenom for a long time, but the question I have is why? Obviously they're able to calibrate exactly but choose not to.
The explanation I've heard is that BMW believes many of its customers switch to different-sized wheels in the aftermarket, so they're protecting the speedometer from under-reading if the customer does not have the car recalibrated. Any truth to this?
2014 335i Sedan 6MT
Estoril Blue | Black leather | Dark Burl Walnut
M Sport | Premium | Driver Assistance Plus | Technology | Dynamic Handling | Cold Weather | 19" 403M Wheels | M Sport Brakes | Harman Kardon | Rear Window Shades | Auto High Beams
09.16.13 European Delivery
Past:
2011 335i Coupe 6MT (ED)
2010 135i Vert 6MT (ED)
2007 335i Coupe 6MT (ED)
2006 325i Sedan 6MT
Old 08-30-2007, 12:06 PM
Chuckycheese Chuckycheese is offline
Mein Auto: 2006 BMW 325xi
Cool I checked!
I've checked mine with a GPS and also the highway radar checks and have found that when the speedometer shows 70MPH...I'm really going 66MPH. An earlier post said the difference is 4MPH and that's exactly what I've found. (I suppose it's less at 30MPH.)
Old 08-30-2007, 01:35 PM
ek_335i ek_335i is offline
Mein Auto: 335i Sedan
The odometer is accurate. The speedometer is not. You can have an accurate odometer and an inaccurate speedometer.
Ed
2007 e90 335i - Delivered 10/7/2006
Sparkling Graphite | Black Leather | Burl Walnut Wood Trim | Premium Package | Sport Package | Steptronic | Paddle Shifters | Navigation | Park Distance Control
Old 08-30-2007, 01:52 PM
BMW Power's Avatar
Ed
Right, that's what I said.
2014 i3 Rex
PCD 11/07
Old 08-30-2007, 02:00 PM
iversonm's Avatar
iversonm iversonm is offline
3 pedals only!
Mein Auto: 2008 550i Carbon Black
EU Regulations, that more or less state that a speedometer can never read low, regardless of the exact brand of tire on the car, etc.
Therefore, they aim for about 3-5% high.
2012 E88 128i, Alpine White/Black
2011 E90 328i, Crimson Red/Black
2008 E60 550i, Carbon Black/Natural Brown, ED 2 November 2007 (retired)
2006 E83 X3, Silver Grey/Black, ED 15 May 2006. (retired)
2005 E46 330i, Jet Black/Black (retired)
2002 E46 325i, Electric Red/Black (retired)
Old 09-01-2007, 08:24 PM
paraboloid paraboloid is offline
Mein Auto: BMW
Are sure about that? Why doesn't Volvo follow the EU Regulation? It has almost 100% accurate speedometer. Maybe BMW wants to make a virtual impression of the ultimate driving machine. You think you drive fast, but a guy in Volvo thinks you are a slow driver. I hope CarAndDriver didn't use BMW's speedometer for 0-60 time measurements . It's sad that none of the auto magazines reported about the speedometer's inaccuracy in different cars.
Old 09-01-2007, 08:55 PM
jwac's Avatar
If what I've heard is true, it could be because Volvo owners don't necessarily swap out wheels/tires with different sizes as much as BMW owners do. So Volvo doesn't need the speedometer contingency plan.
The mags don't watch the speedometer with a stopwatch for their timed acceleration runs. At least I hope none of them do! Many use some form of an independent data capture device, like a GPS-based Racelogic VBOX (Edmunds) or a Datron optical "fifth wheel" (C&D, last I heard).
2014 335i Sedan 6MT
Past:
2006 325i Sedan 6MT
Old 09-01-2007, 10:17 PM
Mein Auto: BMW
Do you really think BMW makes an inaccurate speedometer, because one crazy guy from ten thousand people will install bigger wheels? Isn't it the owner's responsibility to recalibrate the speedometer in a car with bigger wheels?
