E30 (1982 - 1993)
Old 08-29-2007, 08:25 PM
omw41's Avatar
omw41 omw41 is offline
Mein Auto: 1986 BMW 325 E
Common ETA oil leaks?
86 325 E approx 150.000k on her...I have an oil leak. It blows a quart about every 1000 miles. It isn't the valve cover gasket; I recently adjusted the valves and did the gasket at the same time. This leak...I can smell the oil burning...so it has to be coming from up top somewhere,, and hitting the manifold or exhaust.. no? I need to get in there with some light this weekend...but I'm wondering...do you guys and gals have any suggestions where some common problem areas might be and where I should start to look?
Old 08-31-2007, 01:16 PM
omw41's Avatar
No 0ne????
Old 09-02-2007, 02:21 AM
frost_dxb's Avatar
frost_dxb frost_dxb is offline
Mein Auto: C200K, 318i, 325e
same with my ETA too and it looks like every where but the biggest leak i can point out is from the cam sill
2002 C200 KOMPRESSOR
1995 318i - M42B21 on going Project
1992 325i AC Schnitzer - SOLD in DXB
1990 525i - SOLD in DXB
1989 E300 - SOLD in DXB
1989 M6 - SOLD in DXB
Old 09-02-2007, 02:27 AM
AdamAnt's Avatar
AdamAnt AdamAnt is offline
Go Fast
Send a message via MSN to AdamAnt
Mein Auto: 1986 325e
lol...eta jsut loves to throw its juices everywhere, every type of fluid you can imagine will eventually leak from every hole. adds to the fun look around the oil filter and if you have one check the connections at teh oil cooler, also the valve cover.
Old 09-02-2007, 08:48 PM
omw41's Avatar
Zounds good. Thanks guys. I was under there today...it's not the valve cover. My 86 Kawasaki Vulcan leaks alittle oil too. Guess "leakage" is common as one gets older. lol
