E36 (1991 - 1999)
Old 08-29-2007, 08:52 PM
Boogiesox Boogiesox is offline
Mein Auto: 2004 325xi
Is It Normal?
I was just curious if it was normal for the clutch pedal to be able to move from left to right if such forces were put on it. This makes it very frustrating when you have a clutch stop and you worry about pushing the pedal behind the stop. it just seems too sloppy. If this is a problem, is there a simple remedy?
Thank You.
If a mute swears, does their mother wash their hands with soap?
Old 08-29-2007, 08:56 PM
v33_n0d3's Avatar
v33_n0d3 v33_n0d3 is offline
Black Mage
Mein Auto: 2001 325i Sedan
Does it move profusely or just a tiny bit? Be a bit more detailed please.
Old 08-29-2007, 08:57 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
I have the same annoyance, but not that badly, so I'd say its not quite normal. Mine will shift a bit though. Mine can shift maybe a cm or so, but definitely not enough to clear the clutch stop. I'd try to adjust what holds the pedal in place though I'm not quite sure what that'd be.
I fyou have to worry about pushing it around your clutch stop, thats a lot of movement, and definitely a problem.
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 08-29-2007, 09:01 PM
Of course... I jotted that too quickly. The pedal moves about 3 to 4cm either way. It's more of a dampened movement, where as it moves farther it begins to counteract the force you put on it rather than just clunking side-to-side.
Old 08-29-2007, 09:17 PM
PJBIMMER's Avatar
PJBIMMER PJBIMMER is offline
<<<Buddy
Mein Auto: 97' 328I
I'm pretty sure they sell bushings to cure the problem...
check this: http://www.unofficialbmw.com/e36/dri...edal_slop.html
hope it helps...
PJ
Old 08-29-2007, 10:13 PM
Talon328's Avatar
Talon328 Talon328 is offline
Mein Auto: '08 135i
Search for the UUC bushings. They should fix it. I bought mine in May, but uh, still haven't installed them
Old 08-29-2007, 11:11 PM
ianiac's Avatar
ianiac ianiac is offline
<-NIKi
Send a message via AIM to ianiac Send a message via Yahoo to ianiac
Mein Auto: E36 M3
If I say take my car outta gear really fast and push real haard (kinda gripping so i dont slide) than say start turning and downshift.. right b4 i engage itll shift on me a bit every so often..
Old 08-30-2007, 12:37 AM
320what?'s Avatar
320what? 320what? is offline
Mein Auto: 2007 E90 325i
no, 3-4 cm is not normal. mine moves may be .5 cm at most.
Stock '07 Z4 3.0si - Titanium Silver/Black/18s OEM 135M
Old 08-30-2007, 03:26 PM
I looked for UUC Bushings and found the right away. However, could I just run to the hardware store and fing some bushings or is it reccommended that I buy some?
I appreciate the help.
Old 08-30-2007, 03:31 PM
SCANDINAVIAN13 SCANDINAVIAN13 is offline
Resident Pilot
Mein Auto: BMW Not Found
It's better if you buy the UUC bushings. They'll last longer and they won't squeak like other, cheaper options.
Kyle
1993 325is - Frigg - Grounded
2001 Z3 2.5 - Iğunn - Active
Old 08-30-2007, 03:43 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
+1 on the bushes
UUC are excellent
2001 Mini Cooper R50
Edirty6 for life
Old 08-30-2007, 03:54 PM
wag-zhp's Avatar
wag-zhp wag-zhp is offline
Mein Auto: 97 White 328iC
+2 on the bushings, yours are shot if the pedal moves sideways 4cm.
When it absolutely, positively, has to be destroyed overnight! OohRaah!!!
U. S. M. C.
Semper Fidelis
