Old 08-30-2007, 02:53 AM
x3drive x3drive is offline
Mein Auto: X
Center Air Vent Replacement
One of the plastic adjusters has broken on the center air vent, and needs replacing.
Found the part (#64223400074) much cheaper than dealer at http://www.realoem.com/bmw/showparts...=64&fg=05&hl=1
Does anyone know where I can find detailed instructions (and pictures) how to do the swap over?
Old 08-30-2007, 05:44 AM
Mein Auto: X
Just had a play....and the answer is....PULL ....with the aid of a plastic spatula if required. Disconnect bowden cable, pop out the hazard flasher combo switch from behind, disconnect hazard flasher lead and it's out.
Hope this helps someone else.
