E36 (1991 - 1999)
Old 08-30-2007, 03:24 PM
Fab2333 Fab2333 is offline
FAB
Mein Auto: 1992 BMW 325i
Window Not Working Need Response ASAP
OK I need immediate help on this one. I was just tryin 2 put my windows up 3 of them went up and then boom the drivers side window stop going up. At 1st I thought it was the switch that went bad. So then i moved the switch around and it still doesnt work. Low and behold i tried the rest of my windows and none of them are going neither up or down. HELP? wat can I do to fiz this problem ASAP. Im at work inside, and my driver side window is 3/4's up.
Old 08-30-2007, 03:38 PM
ksleher ksleher is offline
Mein Auto: 2008 535xi
try again...if not call the dealer. Sounds like some electronics have gone "bad" ...
Old 08-30-2007, 03:41 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
My vote is the comfort relay buddy if the fuses are ok
You checked the fuses in the engine bay?
2001 Mini Cooper R50
Edirty6 for life
Old 08-30-2007, 03:45 PM
FAB
no didnt get a chance to do that. Im at my desk, my homeboy on his way here 2 take my car home and leave his here. 2 many thieves around here. But to answer your ? didnt get a chance to check the engine bay
Old 08-30-2007, 03:47 PM
Still here
Mein Auto: M3
Fuses first, then the comfort relay buddy
Edirty6 for life
Old 08-30-2007, 04:02 PM
FAB
ok will check it and keep you posted.
Old 08-30-2007, 04:08 PM
PhilipWOT's Avatar
PhilipWOT PhilipWOT is offline
Turn Burglar
Location: Atl: Come for the pollution, stay for the traffic
Mein Auto: Red Assless Chaps
Go outside and grab your window and firmly pull it all the way up while an assistant presses the button up. Seriously, it will work for the time being. I have a 1994 325is and it does the same thin. You'll haveto eventually replace the regulator. but I doubt you want to leave your window down until then.
Old 08-30-2007, 04:37 PM
Still here
Mein Auto: M3
As ALL of them are not working, it must be a fuse/relay problem
If it is stuck open though, the post above is a great idea
Edirty6 for life
Old 08-30-2007, 04:43 PM
FAB
its not the regulator, i just replaced that last week. B/c it kept getting stuck, and the plastic sliding piece kept braking etc. I kno all about the window regulator, this isnt it. This has something to do with the fuse.
Old 08-30-2007, 05:09 PM
FAB
mY FATHER just checked all the fuses in the engine, and he says evry1 of them are working. Now wat?
Old 08-30-2007, 05:10 PM
FAB
I do remember when i was pressing the button I saw like a bright light flash under the switches and then it stopped working.
Old 08-30-2007, 05:17 PM
Still here
Mein Auto: M3
Comfort relay!!!!
Edirty6 for life
Old 08-30-2007, 05:19 PM
FAB
Comfort relay!!!!
WHERE IS THAT LOCATED? AND HOW MUCH IS THIS GOING TO COST ME
Old 08-30-2007, 05:39 PM
Nor-Cal-318 Nor-Cal-318 is offline
Mein Auto: 318IS
I agree with the relay or fuses. I had a 325 that had window gremlins and kept spare fuses in the trunk just for the windows. Also had to replace both window motors.
Check the fuses - good luck
Old 08-30-2007, 05:45 PM
FAB
i checked the fuses already, the fuses are fine.
Where is the comfort relay located?
Old 08-30-2007, 05:54 PM
Mein Auto: 318IS
Look under the dash left of the clutch pedal.
Old 08-30-2007, 06:10 PM
FAB
approx. how much is this going to cost me 2 replace this? or i mean the part itself
Old 08-30-2007, 06:59 PM
Mein Auto: 318IS
my guess $30.00 google it or call the dealer
Old 08-31-2007, 02:08 AM
Still here
Mein Auto: M3
The comfort relay is behind the glovebox!!
Edirty6 for life
