E36 (1991 - 1999)
Old 09-01-2007, 03:52 AM
bxtc bxtc is offline
Mein Auto: 325IA 1992
BMW 325ia - SLOW? (Just got it)
Hi all, im a new member here, tried to search about this "problem" but really couldt find much about it.
I bought a BMW 325ia -COUPE (automatic) a week ago, and when i got it, it had some problems. O2 sensor was failing and such, the car feelt very slow to drive
I got the 02 changed, and the car ran a little better - I cleaned my MAF and the car was again a bit better.
On my onboard BMW computer, my external temp shows -37C all the time, i dont know if that cause anything?
I went to my local dealer/mek and they tested the BMW, i got these errors:
Alternator air to little - What does that mean? - How can it be fixed?
Speed sensor error on both sides - ehh?
So the problem is the car is running really slow, i tried to test it the other day, it runs from 0-60 in about 12 sec - Is the normal for a 1992 325IA?
What could be wrong, what should i check?
It just got a full service, oil, filters and stuff.
Any help will be great, thanks alot!
Old 09-01-2007, 03:56 AM
samsonite's Avatar
samsonite samsonite is offline
I'm here all week
Mein Auto: 1997 318i
Sounds a bit slow, my 318i does 0-60 in about 10 secs!
Old 09-01-2007, 05:52 AM
B/\/\W's Avatar
B/\/\W B/\/\W is offline
Topasblau met
Mein Auto: 328 Ci
Your car should do about 8.2 seconds to 60mph if you really maxed it.
328 Ci
112k miles - 5MT - Electric sport seats - ///M suspension - 225/45/17 Sport Contact 3 - NGK Iridium Plugs - Mobil 1
Old 09-01-2007, 05:55 AM
chet470 chet470 is offline
Mein Auto: 325I
i have a automatic.....mines hits 60 mph in 7 secs although i have some mod work. something is def. wrong my man.
325I
Old 09-01-2007, 05:57 AM
PhilipWOT's Avatar
PhilipWOT PhilipWOT is online now
Turn Burglar
Location: Atl: Come for the pollution, stay for the traffic
Mein Auto: Red Assless Chaps
Yes, that is very slow. You should be in the 7-8 seconds range w/ the auto tranny.
Old 09-01-2007, 06:06 AM
platinum325's Avatar
platinum325 platinum325 is offline
<-----Sweet Jesus!
Mein Auto: 92 325I & 90 325I
keep in mind it's a 92, I assume there is quite a few clicks on the car? I'm sure it could use a tune up but it'll most likely have a best 0-60 of 10 - 11 secs
What you are is a question only you can answer
Old 09-01-2007, 06:13 AM
PhilipWOT's Avatar
Turn Burglar
Nope. Mine is a 1994 with 230,XXX miles on the original M50, and I can bust out a 6 - 6.5 0-60 with the best of 'em. I do have a CAI and Dinan engine software but that stuff doesn't make a 4 second difference. Good maintenance and high quality replacement parts and fluids are the key.
Old 09-01-2007, 06:22 AM
SewerSideUp's Avatar
SewerSideUp SewerSideUp is offline
Spitfire
Mein Auto: 94' 318iS
Do what the computer said. Check you speed senors, they might be dirty with sand or something like that.
Try clearing the code memory on the D.M.E. and drive it for a day then check it again. What are the codes that set ? The ones wich set again are youre problem.
About the alternator air thing, I know that theres an air tube that goes from above the radiator directly to the alternator for cooling. Check that ?
Good luck mate !
Current:
1994 318iS
Sold:
1993 E36 325i
1999 318i E46
Old 09-01-2007, 06:36 AM
B/\/\W's Avatar
Topasblau met
Mein Auto: 328 Ci
I just don't know why you would buy a car that cannot do what it should be able to. There are plenty of perfectly performing old BMWs out there that would have been fast from the start.
328 Ci
Old 09-01-2007, 07:40 AM
I got it VERY cheap, i live in Sweden and could not find so many of these... So i got it cheap and now trying to fix it a bit :P
I had run a check on it again today, it also got one more fault on the computer, it says:
Faulty AC kondensator - i dont know what this is in English, but it is for the AC, it looks like this :
http://picture.yatego.com/images/440.../BMW_148-1.JPG
Can that have anything to do with it?
Any suggestions what it could be, so i dont use alot of money replacing this and that to find out whats wrong??
Is there something i should check first? About the speed sensors what do they actually do?
Old 09-01-2007, 07:51 AM
PhilipWOT's Avatar
Turn Burglar
That's A/C Condenser is english. It can be expensive. Try to source a used one.
Old 09-01-2007, 08:35 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
i would suggest the camshaft sensor, but as i have already suggested that to someone else, i will refrain
Have you checked your fuel and air filters? they may need replacing (cheap)
Should also check for air leaks, especially in the intake boot (the big black one between the engine and air filter housing
330i M-Sport in Topaz Blue
Edirty6 for life
Old 09-01-2007, 08:36 AM
PhilipWOT's Avatar
Turn Burglar
Did you invent the E36?!?! How is it that no problem EVER stumps this guy? It blows my mind, seriously.
Old 09-01-2007, 08:38 AM
Still here
Mein Auto: M3
Why thank you mate.
I just spend too much time on here and playing with my car buddy
Edirty6 for life
Old 09-01-2007, 10:05 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is online now
King of the Ballers
Mein Auto: Dreier, Fünfer & Siebener
Has it rained lately?
Kidding buddy, ignore what I said....
Anyway, I'd say whatever Pirate says is probably your problem. If it just feels sluggish at all times, I'd go with Pirate on it being a sensor for sure.
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
Originally Posted by SlimKlim View Post
You're a derbanana
Old 09-01-2007, 10:34 AM
Still here
Mein Auto: M3
lol, thanks
Edirty6 for life
Old 09-01-2007, 11:43 AM
PhilipWOT's Avatar
Turn Burglar
Pirate-
: you know, one thing we didn't think of was that his problem could be the 2 extra doors weighing his car down..
Old 09-01-2007, 12:40 PM
Still here
Mein Auto: M3
I reserve judgment until Tuesday....
Edirty6 for life
Old 09-01-2007, 12:45 PM
King of the Ballers
I may not be around for much longer, so will leave my 'fcuk you' thread until then!!.
Hold on a minute.....just what do you have up your sleeves? Are you leaving us for some 4 door? Watcha got planned mate?
You're a derbanana
Old 09-01-2007, 12:51 PM
Still here
Mein Auto: M3
...maybe
Edirty6 for life
Old 09-01-2007, 12:53 PM
PhilipWOT's Avatar
Turn Burglar
Oh, for the love of small useless back seats!!
One of our most dedicated and die-hard coupe enthusiasts leaving the the team for a mommy car?! Say it isn't so!
Old 09-01-2007, 12:55 PM
Still here
Mein Auto: M3
It isn't so
Well done on the reverse psychology though mate, it worked a treat....
Edirty6 for life
Old 09-01-2007, 12:57 PM
PhilipWOT's Avatar
Turn Burglar
It isn't so
Reverse psychology? I dont think I'm with you? I was being serious. If you leave the coupe team, it's down to me and Phantom.
Old 09-01-2007, 12:58 PM
Still here
Mein Auto: M3
Down to you two to what?
Phantom is an elite, you are a pain!
I will never leave you all together, i have too many friends here but we all gotta move on sometime!
Edirty6 for life
Old 09-01-2007, 01:10 PM
wyatt wyatt is offline
Mein Auto: 318i (1994)
When it works right consider an engine chip from Bavarian Auto Source. I put one in my 1994 318i automatic and it made a considerable difference. $225.00 plus one hour shop time installing it. Well worth it to me.
