E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Help needed
I have a 96 E36. I'm a bit thick when it comes to the working of a car. I need some advice. Sometimes when driving and quite often on braking the car pulls slightly to the left. I'm thinking either the tracking is out or wishbones.
I would be grateful for any advice. |
Its most likely your wheel alignment, or you might need new tyres.
If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them. -- Henry David Thoreau |
Just changed the tyres so maybe the alignment. Thanks for the info.
Thats probably what it is then, if you just changed them. Did it start doing it after you got them, or has it been going on before?
alignment
It was like it before I changed the tyres.
Any vibration??
330i M-Sport in Topaz Blue Edirty6 for life |
No vibration. Is that a good thing?
Yeah, means your brake pads and Rotors are not warped
Thanks for the advice guys
Spoke to Kwik Fit about getting the alignment done on my car and was told only BMW can do it. Does anyone know if it can be done anywhere else as BMW quoted me 350.00gbp.
Please say I don't need to pay that much. |
Pirate, I had new tyres and alignment done a few months ago, but the car still moves to the left slightly if I don't hold the steering wheel, and the steering wheel shakes under braking. Why would I have warped brake pads and rotors? Is that what it could be, or just worn parts in the steering gear?
328 Ci 112k miles - 5MT - Electric sport seats - ///M suspension - 225/45/17 Sport Contact 3 - NGK Iridium Plugs - Mobil 1 Last edited by B/\/\W; 09-02-2007 at 04:03 AM. |
Just another quick tip.....make sure the tire pressures are equal. if there not, that could cause the pulling as well.
Cone XXX
ALSO, IT SHOULD BE NOTED:......AMATURES BUILT THE ARK..AND PROFESSIONALS BUILT THE TITANIC..................QUOTE FOR THE DAY.. Good drivers know how to get out of trouble, and better drivers know how to avoid it..... The Cone 2006 & 2007
good call cone!
BMW, if your car's steering wheel vibrates under braking then your rotors are warped. Thats the main reason. |
I just did some reading about this issue. I might have a look into high quality ceramic pads and standard rotors, as the issue seems to be that a rotor is a rotor, made of iron, whereas the pads are composites and the best ones are made to be heat resistant. The copper filaments in the ceramic help to draw heat away from the rotors, which prevents warping of them because they don't get as hot. So pads seem to be the key here.
328 Ci 112k miles - 5MT - Electric sport seats - ///M suspension - 225/45/17 Sport Contact 3 - NGK Iridium Plugs - Mobil 1 |
I didnt know that
![]() You learn something new everyday. Thanks bmw! |
2. Any tire place got do it or major garage over here in the uk. Agree with Cone. the tyre pressure could be the key on this one, so check that out first, as its free to do so.
We are all allowed to make mistakes.....we are only judged on how we fix them!
plus diffrent makes of tyre on the same axle can do this as well but mostly on the front |
Mine shakes sometimes and not others, I know it's pads and rotors because I checked the bushings, I was just curious to why it would only do it every once in a while
She's good, but I keep finding Barbie doll's under the hood. |
That's actually true of mine as well, it doesn't always do it under braking, weird eh?
