E36 (1991 - 1999)
Old 09-01-2007, 06:53 PM
Andye36 Andye36 is offline
Mein Auto: e36 325is
Question on gauge cluster
my tach is going kaput on my 325.
my question is will a m3 gauge cluster plug right up(same plugs on harness?), because i will most likely change to a s52 someday and i really see no need on getting another 325 gaugecluster(redline low). The second question is will the 325 ecu drive the tach just fine? or would i need a tach adaptor.
my car is a 09/92 325is 5speed.
thank you in advance,
Andy
Old 09-01-2007, 07:21 PM
PJBIMMER's Avatar
PJBIMMER PJBIMMER is offline
<<<Buddy
Mein Auto: 97' 328I
It should work just fine......always match a six cyl. gauge cluster with a six cyl. Remember that a 4 cyl. cluster won't work on a 6 cyl. car.......PJ
PJ
Old 09-02-2007, 05:42 AM
DominguesE30's Avatar
DominguesE30 DominguesE30 is offline
BMW FETISH!!!
Send a message via MSN to DominguesE30
Mein Auto: `97 BMW 318is
i dont know if it will work. It might but ive always been told to match up the clusters on the e30's orelse it will go haywire!
You can be our test tube. Pj may be right here thought..
MADEINDEUTSCHLAND
`00 BMW e46 330i
`97 BMW e36 318is
Beeeeeeeee Eeeeem Double-YOU!!!!
Old 09-02-2007, 09:45 AM
well the difference on 4cyls and 6's it the timing pulse is different, so a 4cyl tach would be at redline at like 3k on the engine.
