Power steering advice needed - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 09-05-2007, 02:17 PM
greese greese is offline
Mein Auto: 1988 bmw 325i & 1988 Linc
OK, fluid is leaking from the pump and the resevoir is dry. Hence, I think the pump is shot. Here are the options I'm considering;
1. Reolace with a remanufactured pump from Murray's ($105)
2. The dealer manual (thanks Bryce) says to replace the seal and o-ring. My dealer says he can order a "kit" for $41.
3. Buy some power steering fluid with the so-called sealant (I know I'm supposed to use ATF but that stuff always worked on my Lincolns).
Also, with the exception of backing out the diveway (low speed), the car steers almost normal. Am I screwing up something else up by driving it this way?
Old 09-05-2007, 02:34 PM
omw41's Avatar
omw41 omw41 is offline
Mein Auto: 1986 BMW 325 E
I would go with the rebuilt.
