new brakes installed & having high pitch yelling sound..what now? - Bimmerfest - BMW Forums
Old 09-05-2007, 06:16 PM
SPLITSENSETAM's Avatar
SPLITSENSETAM SPLITSENSETAM is offline
Mein Auto: 2011 535i xdrive
hey eveyone ! i just had new brakes installed on my 528i i went with the oem brembo rotors and pagid pads all around the car cause i was thinking it will produce the less noise possible ..everything is all good with very little noise except when i depress the petal down at about 1/4 at very slow speeds i get a high pitch yelling type sound and goes away if i go down more towards the 1/2 way mark ?...what gives ? how can i cure the problem?
thanks !
SFMV97528I
Old 09-05-2007, 06:24 PM
MatWiz's Avatar
MatWiz MatWiz is offline
Psychology Reversalist
Mein Auto: 528
Did you install the shims? Their job is to prevent the vibrations that create the noise.
But I never install the shims...
You need to bed the brakes, and the noise will go away. Look at www.zeckhausen.com for the bedding procedure.
Anyway, if you don't do anything, it will do away after a few weeks.
MatWiz
"The greatest thing about the internet, is that you can quote something and totally make up the source." - George Washington.
Old 09-05-2007, 06:45 PM
to tell you the truth i have no clue i had my indie install them for me.
im guessing he didnt ...how long am i gonna have this sound for does it mess anything up?
if it goes away within the weeks im fine with that ..
thanks matwiz!
SFMV97528I
Old 09-05-2007, 07:07 PM
MatWiz's Avatar
Mein Auto: 528
Well, do the bedding anyway. It's a great thing to do to your brakes, and it is a lot of fun, as it involves driving you car like a maniac...
See my post here for a shot explanation about the bedding process. here: http://www.bimmerfest.com/forums/sho...d.php?t=228458
MatWiz
Old 09-05-2007, 07:16 PM
Rainman15 Rainman15 is offline
Mein Auto: 01 330CI Convertible
When I did my front pads I missed one shim and didn't realize it until after I was putting the wheels back on. I figured it wouldn't make a difference, but I ended up with the exact same squealing you are describing. I took that side back apart and installed the shim. Problem solved, dead silence under all braking conditions. I couldn't believe that one shim made that much of an impact on the way the brakes worked and sounded. I'd bet he missed one or all of your shims when he did your installation. Steve/Staten Island.
Old 09-08-2007, 10:04 PM
m5james's Avatar
m5james m5james is offline
Send a message via AIM to m5james Send a message via MSN to m5james Send a message via Yahoo to m5james
Mein Auto: 98 740iL - Tweaked a bit
You need shims and/or brake pad lube on the backside to stop the squeeling...it won't fix itself unfortunately.
640hp 10 X5///M, Alpine White/Sakhir Orange - Gutted cats, muffler delete, Eurocharged tune
325hp 98 740iL, black/black - Eatin 540's & $hittin 318's
PERFORMANCE:///M5 6spd swap, Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd
INTERIOR:
Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint
EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads
