E30 (1982 - 1993)
View Poll Results: Does the CAI give you more hp?
Yes, noticably 1 50.00%
Not that i can tell 1 50.00%
Sometimes 0 0%
Voters: 2. You may not vote on this poll
Old 09-05-2007, 07:23 PM
wpstriker89 wpstriker89 is offline
Mein Auto: '88 325ic
AFM question
If i was to put in a K&N CAI (http://www.knfilters.com/search/prod...x?Prod=57-0070) with the heat shield (http://www.signaturemotoring.com/Col...r%20Intake.htm) would the only change needed be that i need to remove the AFM? or should it fit directly in front of the AFM? Just kindof confused as to where exactly the CAI would fit in correctly. And curious if anyone has any negative experiences with a CAI in general. Thanks for all the help.
'88 325ic *light and quick!*
Old 09-05-2007, 07:36 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
The CAI will replace you airbox and sit immediately upstream of your AFM. It does not replace your AFM.
I Timothy 2:1-2
Old 09-06-2007, 09:23 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Where is the NO!, but it sounds cool option?
