E46 (1999 - 2006)
Old 09-19-2007, 08:48 PM
jrighter jrighter is offline
Send a message via AIM to jrighter Send a message via Yahoo to jrighter
Mein Auto: 2000 323i Sports/Prem
BMW codes 202, 203 227, and 228
Need help here. These aren't the OBDII codes but the BMW codes. 2000 323i This is for a possible new purchase and the owner is saying these are the codes BMW gave him from the check engine light. I'd like to verify what they are and how to fix them.. They told him rich mixture
Old 09-19-2007, 09:15 PM
v33_n0d3's Avatar
v33_n0d3 v33_n0d3 is offline
Black Mage
Mein Auto: 2001 325i Sedan
202: Fuel Trim (bank 1)
203: Fuel Trim (Bank 2)
227: Fuel Control (Bank 1 Sensor 1)
228: Fuel Control (Bank 2 Sensor 2)
Sounds like a case of crappy gas to me.
Old 09-19-2007, 09:25 PM
Thanks! Any suggestions on how to fix it? The owner said it has been reset but eventually comes back on..
Old 09-19-2007, 09:30 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
With any fuel-related codes, I'd replace the plugs and fuel filter first.
Old 09-19-2007, 09:33 PM
He did have the plugs replaced but I don't believe the fuel filter was done. So I'm assuming this isn't something that I should be real concerned about? Everything else on the car ha checked out fine. Thanks again for all the help! BTW 85,000 miles..
Old 09-19-2007, 09:38 PM
v33_n0d3's Avatar
Black Mage
The fuel filter was never replaced in those 85,000 miles? Oh yeah, definitely do that ASAP. Also, did you put any additives in the tank?
Old 09-19-2007, 09:39 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
It could be something to be worried about. No way to really tell until you've confirmed the root cause.
I personally wouldn't buy any car with error lights on. If the previous owner didn't care enough to at least get the issue diagnosed, who knows what else is going on.
Old 09-19-2007, 09:46 PM
I agree on not purchasing with the error light. The car seems fine, he had it checked by the dealer, they replaced the plugs and it came back on with the same codes a few weeks later. He actually even has the invoice for this. Not sure why they wouldn't have changed the fuel filter. The only other issue he has warned me about is the passenger side regulator is starting to go. I've replaced these so I'm not worried about that. He is the second owner with all the service records, oil changes evey 3000 miles, etc...
Old 09-19-2007, 09:58 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Hm, tough call then.
Old 09-19-2007, 11:00 PM
Yeah, I know What P codes do these translate to?
Old 09-20-2007, 02:21 AM
BMWtech75 BMWtech75 is offline
Mein Auto: IS300
Check your intake boot. Possible crack in boot. Might need an engine harness. I have seen those fault codes before & it could be either or.
Old 09-20-2007, 04:38 AM
crowz's Avatar
crowz crowz is offline
Mein Auto: '00 323i/97 528i/94 318is
Id doubt he would have harness issues without some cause for it such as someone tinkering around with it or a wreck. But the tube leading from the mass air flow sensor is a good thing to check.
Old 09-21-2007, 11:27 AM
Mein Auto: IS300
Not neccesary. The corrosion in the contacts alone will cause it. There is a bulletin for fault code 227 & 228 to replace the engine harness on the X5 3.0 which is pretty much the same engine. I have replaced the harness before on an E46 & it fixed the problem. Just letting him know from past experience.
Old 09-21-2007, 02:04 PM
Yikes! Engine harness? I guess the car has some slight hesitation in the mornings if you take off immediatly. Could it be a MAF?
Old 09-21-2007, 10:25 PM
Mein Auto: IS300
Doubt it. With what you just said, I would lean more towards a torn intake boot. Really common place for the intake to tear is where it (smaller intake hose)bends right before going to the throttle. I'll try to take a pic for you of the common place to look tomorrow when I get to work.
Old 09-21-2007, 11:06 PM
Thanks for the help!
Old 09-21-2007, 11:27 PM
Mein Auto: IS300
No problem. Hope it is just something simple for you. Let me know if I can be of any other help.
Old 09-21-2007, 11:48 PM
Me too. This has been stopping me from pulling the plug and buying this car. I can't decide if it's a good deal or not. Here in Ohio 3 series seem to be at a premium whereas the 5 and 7 series can be had very reasonable. Too bad I don't want a 5er! 2000 323I well maintained, 85k miles, 5 spd, Sports/Premium for 11k. If it weren't for this stupid SES issue. This will be my 5th BMW, one of the cheapest but I guess I'm becoming a tight ass after I hit 30! I'm very specific on my needs so that is part of my issue. I guess I should say "wants" not "needs". Gotta be Blue or Black exterior, black interior only, 5spd, well maint, Sports/Prem, and sedan.I went today and tried to plug in my Actron CP9175 OBDII scanner in the port just to confirm the readings for myself and it didn't seem to fit. I cannot win for losing!
Old 09-23-2007, 01:03 AM
crowz's Avatar
Did you remove the plug first? Theres a plastic cover over the obd port.
Old 09-23-2007, 07:45 AM
Yeah, I got it. I'm not a total idiot. LOL! I just wasn't pushing it in far enough. The plastic that surrounds the port just makes it a very tight fit. I was afraid to force it but did so and what do ya know it snapped in! It slides into our Nissan with no force at all. Actually I never had to force it when I plugged it into my 2 previous 5 series either. Anyway, puled codes 1188, 1189, PO173, and PO172.
Old 09-23-2007, 10:16 AM
Actually the codes were PO173, PO170, P1189, AND P1188
Old 09-26-2007, 10:03 PM
Just wanted to give a big thank you to everyone here, especially BMWTECH. I took the chance and purchased the car Monday. Glad I did! After removing the air filter for a further inspection of the intake boot, sure enough the little elbow was completely ripped in half. Local BMW had the booger for 17 bucks. Replaced the intake boot, started the car, and discovered the sputter was completely gone so I reset the codes and sure enough they did not return as they did before when I reset prior to the boot install. The 17 dollar trip turned into $120.00 trip at the local stealer. I went ahead and changed the oil and filter, fuel filter, rear license plate bracket and air filter while I was at it. I cleaned the MAF for a little preventative maintenance as well. I saved the elbow and will post pics sometime this week for others to see since they could very well have the same issue. Thanks again guys!
Old 09-27-2007, 05:32 PM
Mein Auto: IS300
No problem. Glad everything worked out for you. Enjoy your new vehicle.
Old 09-01-2015, 11:35 AM
JessB JessB is offline
Mein Auto: BMW 325i
HELP! Codes 143, 228, 227 and 068
I have a 2002 BMW 325i/ 140,000 miles. All four of these codes popped up at the same time and I don't even know where to start.
143- Tank Leak diagnosis with DMTL
228- Fuel trim bank 2
227- Fuel trim bank 1
068- Activation, solenoid valve, tank ventilation.
I bought a new fuel cap a year ago. Wondering if it could be a bad sensor. Or maybe lower intake boot or elbow tube? But what would cause all four of these codes at once? Any help would be greatly appreciated!
