Old 09-20-2007, 12:29 AM
Phat2000 Phat2000 is offline
Mein Auto: 2000 540i
Bad Volume Knob on Radio - Need Fix
2000 540i - Stereo W/Navigation: Hoping for simple solution to replace knob without having to replace the whole unit. According to the dealer the knob is part of an assembly and is not repairable otherwise. They price the job at about $600, which is not going to happen. Any suggestions?
Old 09-20-2007, 12:28 PM
michelinman michelinman is offline
Mein Auto: 540ia
Do you have problem with the volume knob not turning the volume up/down? Had that problem with mine and thats because I tend to most of the time, use the steering wheel volume controls instead of the one on the radio. The volume knob electrical contacts were not making after not being moved for a long time and to "fix" that, I turned the volume knob up and down quickly several times until the knob works ok.
I just have to remember to use the volume knob on the radio unit once in a while to prevent the same problem from reoccuring and its been good since.
2000 540iA Cosmo Black, Sport Pkg, Premium Pkg, DSP, CD changer
Old 09-20-2007, 01:23 PM
bimmerd00d's Avatar
bimmerd00d bimmerd00d is offline
just havin a heart attack
Send a message via AIM to bimmerd00d Send a message via MSN to bimmerd00d Send a message via Yahoo to bimmerd00d
Mein Auto: 1998 540i 6-speed
www.bmaparts.com
you need part #65828372162, $3.79. I believe the standard knobs from the regular MID are the same ones. I am not certain of this, but from looking at them in person they look the same to me. If not, you could probably make it fit at $3.79
Here is another option, if you look at a widescreen nav unit, you can buy the knobs individually, they look the same to me. part number #65528385458
http://www.realoem.com/bmw/showparts...92&hg=65&fg=45
2011 535i xDrive M-Sport - 114k miles
2003 Land Rover Discovery 2 - needs a core support or a new owner (cheap)
2005 Dodge Ram 2500 - Cummins with a Bully Dog and some goodies
Old 09-20-2007, 07:44 PM
Thanks for the info. Contacted Dealer with part no. you provided and as it turns out it's a simple and inexpensive fix. Dealer cost for part is less $10. The cost was originally misquoted because they assumed I was using a different stereo unit. Thanks again!
Old 09-21-2007, 05:44 AM
bimmerd00d's Avatar
awesome, glad i could help!
Old 09-21-2007, 11:18 PM
hosnimax hosnimax is offline
Mein Auto: M3 2003 and 528iA 1997
intersting information thanks
Max
Old 09-22-2007, 01:55 PM
Interesting. Quickly turned knobs up & down frew times as suggested by "Michelinman" above, and it seems to have done the trick! Original problem with knob was that when I turned the knob, the volume was erratic and would go extremely high or low... basically uncontrolled and annoying. I too very rarely used volume control on radio deferring to the steering wheel control. Thanks again!
Old 09-28-2007, 12:49 PM
aiyagari aiyagari is offline
Mein Auto: 2003 330i Performance Pkg
Thumbs up Thanks, got it from Pelican
I have the same problem, but even worse -- the knob's volume function came back when I used the suggestion above (turn it back and forth quickly), but the on-off function (pressing the knob in) is not working properly -- you have to push the knob in really hard because the rubber springy action seems to have gotten spoiled. Dealer wants $900 to install new stereo -- ridiculous. Real OEM found me the part number, but their shopping cart is not working; went to Pelican Parts and ordered from there, should be coming in a couple of weeks. Thanks again for the info on how to find BMW part numbers. Even with shipping it will only be $15.
Old 12-13-2007, 12:52 AM
refimail refimail is offline
Mein Auto: 2003 325i
aiyagari,
I recently ran into the same problem with my E46 radio (I had to press the volume knob hard to turn on/off the radio). I noticed that I could make the knob wobble slightly on its axis. I removed the head unit from the dash and, looking inside the housing just behind the radio knob, I noticed that the plastic white piece that held the tiny circuit board assembly, behind the radio knob, broke off from the mating surface of the inner part of the clear plastic faceplate. I carefully realigned and Super glued them back together, using a fine-tip pen dispenser, and haven't had a problem so far.
Old 12-13-2007, 06:32 AM
Jase007 Jase007 is offline
Wrenchin' fool ...
Mein Auto: e39 528it
I checked the part numbers provided above:
65828372162
65528385458
.. and these are for the radio button only. I'm not saying the rotating volume control quickly doesn't work but that I think the problem is with the actual on / volume mechanism. Lack of use may allow corrosion on the internal contacts and movement corrects but ... eventually I think it will fail again.
I have a similar volume problem but my actual problem is the on/off / volume mechanism IN the MID. These seem to be cheaply made as I have two MIDs and each has axial play [remove button and manipulate post]. On one of my MIDs I can actually apply slight axial pressure and it will turn radio on and / or off. Something internal where the post rotates to change volume shorts and radio power is cut. Typically, you'd have to push button / post in against detent to make this happen.
Will be opening opening mine up like refimail to investigate and will let you'll know if interested.
Jason
2000 528iT Sport 5M (mfg. 5/1999) ~ 1990 325iX 5M
BMW CCA member #130075
JScottRacing
Old 12-13-2007, 02:17 PM
bimmerd00d's Avatar
If your pixels are dying on them, the dealer will replace this under the same warranty repair as the Instrument Cluster pixel issue. BMW of Dallas did for me at least, I had an E90 330i for a week while they located and installed the piece!
Old 05-06-2008, 11:53 AM
rockfish66 rockfish66 is offline
Mein Auto: '93 325is
Sorry to wake a sleeping thread, but...
I have an '03 325i with the Business CD and I had the fussy operation and "axial play" of the volume/on-off knob mentioned above.
Yesterday, the knob stopped working completely. It spins freely on its axis without changing the volume, and will not push-in to turn off the radio. If I pull the knob out slightly it seems to re-engage and I am able to change the volume, but if I try to push it in to turn off the radio it just "gives" with no resistance and bottoms out.
I have 2 questions:
1) If I buy the knob and try to replace it, how do I get the old one off? Do I just pull it off?
2) If it turns out out I need to get into the radio to do some glue-ing, is there a DIY posted on taking out the radio?
Thanks in advance.
_________________
(oo-00-oo)
'03 325i, '93 325is
Old 05-14-2008, 11:06 AM
Originally Posted by rockfish66 View Post
I have 2 questions:
Thanks in advance.
I had the same problem. You can pull the knob straight out and check for stripped threads. My radio knob was fine.
Look for the DIY to remove the dash trim and radio. Look for my post above and check if the knob's small circuit board is securely attached to the clear plastic inner faceplate. If not, Superglue them back together. Good luck.
Old 08-02-2008, 10:35 AM
blogger247 blogger247 is offline
Mein Auto: BMW 330CI
Stereo keeps loosing sound
Hi i thought my stereo had the same fault as above but it doesn't seem the case.
I have a 330 with the screen sat nav stereo and the sound keeps cutting out with no real ryme or reason. I have taken the head unit out to look at the volume knob but that seemed fine. When the stereo was out i drove the car and the cd was playing fine and then cut out as per usual so i think im right in assuming that is not the issue. When the sat nav is on the instructions come out loud and clear even when the stereo cuts out.
Any ideas would be great.
Old 08-23-2016, 11:13 AM
bigstud4ubaby bigstud4ubaby is offline
Mein Auto: 2008 BMW X3
How to clean the volume knob so it's no longer flaky
Takes a few minutes to clean w/contact cleaner, you can hear the before and after
