E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
Engine ID
From an old Technical reference information bulletin. The attachments referenced do not show the newer engines.
Sort of matches the one on my S54 engine. Vin LK60049 manufactured 05/01. Production day doesn't make sense. On the S54 engine the number is on the right hand side of the block below the headers where it meets the oil pan. My engine: 6 104 2 493 32 6 S4 Anyone else have the numbers on their S54 engined car?
not to take away from the info , but im wondering if the Steyr in austria which is the company that will be doing the bmw X3 project is the same Steyr Augh that makes high end weapons
http://www.bmw-werk-steyr.at/
"Effective leadership is not about making speeches or being liked; leadership is defined by results not attributes." |
Adding engine ID pic
![]() Randy Forbes 1957 Austin-Healey 100/6 Wine Red 1961 McCulloch R1 go-kart Screaming Yellow 1999///M Rdstr Cosmos Black 2001///M Rdstr Steel Gray 2011 X5 35i Sport Deep Sea Blue/Cinnamon |
Someone stopped by yesterday to do some things. One of the things we ended up doing was to check his engine serial number.
Turns out it is the one just before mine. How about that. If you S54 guys get a chance, would you check yours and let me know. Trying to correlate engine serial number to engine failure. The following is what I have so far. Not much .Dale---6 103 2493 LJ80138 04/01 EPC, 05/01 B pillar Ron----6 104 2493 LK60049 05/01 Al------6 120 2514 LJ80291 06/01 Randy--6 086 2554 LJ80510 08/01 Last edited by Ron Stygar; 08-11-2003 at 10:38 PM. |
Off topic, new jackstands arrived today, but I'm still waiting on the new floor jack. When it arrives, the carrier arm you sent me will go in, along with the shifter from Randy and final checkups before the HC voyage. I had a heck of a time finding someone to ship me a DK13HLQ before HC... apparently there's only one importer and they're waiting on a shipment. Steve (Ultimate Garage) had one in stock but only for pickup, ASE had none in stock and a lead time of several weeks, etc. Finally found All Tire Supply in TX had a few in stock and would ship on Thursday. ![]() Any way you might make me a set of jackstand adapters for these if I sent you one of the posts? Or maybe you already have something that'll work? I know about your jackstands, I just really like the AC units and they were reasonably priced from Steve.
Daniel 2002 M roadster |
Ron keeps his in a spare bedroom and mine is stashed in the basement behind stacks of wheels, hardtops and M Rdstr exhaust systems.
I have the crossbeam adapter coming for the jack too, but I've yet to try to figure out if it's going to be usable on the roadster. Ultimately this is all mostly temporary in terms of using it for the roadster, there's a 4-post lift in my not-too-distant future so the jacks will be relegated to those times when I need to unload the suspension. It's just a hell of a lot easier to push a button and lift the whole car at once. The 220 and subpanel were installed earlier this year, I just haven't bough the lift yet because I keep pondering which one to buy (I want the Bend-Pak, but it'd be nice to have a center decking option and they don't appear to offer it and I don't know if others will fit or if I'll have to make some). The crossbeam adapter will be usable on our truck, and probably the A4 should I ever need to get under it (it's leased, no mods going on there).
Nice jack stands! You are going to love the jack. It took 2 trys to get me one in good shape, but I believe they've since improved their packaging methods. Fingers crossed for you. If that doesn't pan out, I know that Kinesis (the wheel company) is now the (one of?) AC importer.
Back on topic, I'm pulling my underbody shield tonight and not putting it back. I'll check the engine serial while I'm at it and report back. |
Sorry to get so far off topic.
Here's mine (12/01 build M roadster, model year 2002):
60712655 So now we have: Dale---6 103 2493 LJ80138 04/01 EPC, 05/01 B pillar Ron----6 104 2493 LK60049 05/01 Al------6 120 2514 LJ80291 06/01 Randy--6 086 2554 LJ80510 08/01 Daniel-6 071 2655 LJ82311 12/01 It'd be nice to get some from E46 folks, and some more from the 'dreaded' build period.
The 6 prefix remains constant but the next three numbers seem to count down (though Al's doesn't follow this) while the last four numbers count up.
![]() ![]() ![]() ![]() to the dealer or hire a class action product liability attorney... So they've moved to this type of coding for their production lines.So looking at the posted numbers with my interpretation: Dale---6 103 2493 LJ80138 04/01 Ron----6 104 2493 LK60049 05/01 Al------6 120 2514 LJ80291 06/01 Randy--6 086 2554 LJ80510 08/01 Dale & Ron's engines were made next to each other on the same production day (493). Al's was the 104th produced on the 514th production day. Yours #86 on the 554th production day. So yours would be the newest & Dale's & Ron's the oldest of the group. You need to get some engine numbers off the bad engines and try and compare them to the last set of 3 numbers to see if any of you guys are close to the suspect lot...
Bo Lewis |
Adding mine...
Dale---6 103 2493 LJ80138 04/01 Ron----6 104 2493 LK60049 05/01 Dan----6 111 2495 LK60113 06/01 (b-pillar) Al------6 120 2514 LJ80291 06/01 Randy--6 086 2554 LJ80510 08/01 |
Somehow mine got dropped...
Dale---6 103 2493 LJ80138 04/01 Ron----6 104 2493 LK60049 05/01 Dan----6 111 2495 LK60113 06/01 (b-pillar) Al------6 120 2514 LJ80291 06/01 Randy--6 086 2554 LJ80510 08/01 Daniel--6 071 2655 LJ82311 12/01
This is just slightly off-topic. My S14 engine block has the following on it:
60034093 23 4E A According to the info that Ron posted, here's what it means: 6: S14 003: Serial Number 4: Munich 093: Production Day 23: 2.3 L 4E: 4-cyl fuel injected A: USA? Anyway, what does Production Day mean? Day of the year? It was built in 1987, which wasn't a leap year, so day 93 would have been April 4. That doesn't exactly match the rough production date of my car, gathered from the VIN. Hmm.. |
'06 330i 6MT Sedan: MB / Terra / Burl / Sport / Cold |
Here's mine. My camera sorta sucks...
Jon Maddux 10 S1000RR | 09 F650GS | 08 E90 M3 | 07 R1200RT | 06 M Coupe | 01 M coupe |
Ron----6 104 2493 LK60049 05/01 Dan----6 111 2495 LK60113 06/01 (b-pillar) Al------6 120 2514 LJ80291 06/01 Randy--6 086 2554 LJ80510 08/01 Daniel--6 071 2655 LJ82311 12/01 JonM---6 115 2557 LK60238 08/01
sorry to but in here being that this is more of a M// motor thread, but does anyone know if all bmw z3 engine's came from the steyr plant, as in the 3.0 as a example
max |
That is my belief. But if I'm wrong, twenty people will correct me...
#25
Racing s54's
Has anyone contacted the shops that campaign the s54 engines in the big series'. Don't the chilli pepper guys use s54's? They would likley know about the s54 problems. Bimmerworld, turner etc. just an idea.
2000 Imola Red M Coupe Dinan suspension, M rotors /Axxis pads Eurosport Cam Kit 1, touch lane change Zaino polish, Beach Sand Garys mirror adapter, S54 Oil Cooler seat tilt coupling nuts, spare tire "life's to short to drink cheap beer"
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
