Old 01-06-2007, 11:22 PM
Ron Stygar's Avatar
19,585 Miles
Originally Posted by Ron Stygar View Post
From an old Technical reference information bulletin. The attachments referenced do not show the newer engines.
Sort of matches the one on my S54 engine. Vin LK60049 manufactured 05/01. Production day doesn't make sense.
On the S54 engine the number is on the right hand side of the block below the headers where it meets the oil pan.
My engine:
6 104 2 493
32 6 S4
Anyone else have the numbers on their S54 engined car?
My Z3 M coupe:
6 104 2 493
32 6 S4
Z4 M Coupe: Still don't know what it all means.
6 157 3 765
32 6 S4
You have to remove the reinforcement plate to see this.
Took it off to powder coat it.
Also to add a water temp sensor in the anti-freeze drain plug.
Doable but not as easy as the S54 Z3 getting to it wise even with the plate off.
Old 01-07-2007, 01:07 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
Dale 6 103 2493 LJ80138 04/01
Dwayne 6 104 2493 LK60049 05/01
Dan 6 111 2495 LK60113 06/01
Al 6 120 2514 LJ80291 06/01
Randy 6 086 2554 LJ80510 08/01
JonM 6 115 2557 LK60238 08/01
Daniel 6 071 2655 LJ82311 12/01
Ron 6 157 3765
I'm guessing the 4-digit part is production day, and the 3-digit part is the engine number within that day.
Let's assume the production day is days the line is running, and that the M engine line doesn't normally run on weekends, so it's mostly only weekdays being counted.
This lines up pretty well when comparing production dates to engine numbers above, given the amount of potential slack in the supply chain. Someone in Spartanburg probably has a rough idea how long an S54 might sit before being mated to a chassis, and how long it takes for one to come across the pond. One of those pointed questions I always forget to ask on the plant tour: "How far ahead of scheduled assembly date do you receive S54 engines? Are there any in the plant that are still awaiting an order to match them to a chassis? Closer to 0 or 20? If they're delivered JIT, what's window for them? A day? A week? Longer?"
Assuming this is correct, Dwayne's (formerly Ron's) '01 M coupe engine was right behind Dale's in engine assembly. Ron's 3765 would be about 14.5 years. BMW introduced the S50B30 for the E36 M3 in 1992. Same engine assembly line?
Daniel
2002 M roadster
Old 01-08-2007, 08:49 AM
Fast6 Fast6 is offline
matching revs in
Ron 6 157 3765
The second block isn't 4 digits, but rather 1+3. The first number in the second block (5th number overall) designates the engine line, and the second through fourth in the second block (6th-8th overall) designate the production day.
So Ron's, for example, should be
6 157 3 765
Which is:
Assembly line: 6
Serial #: 157
Factory code: 3
Production day: 765
So what's curious to me is that an S54 in a brand new car was built on the 765 production day. That 765th day could mean lots of things, like since that assembly line (6, looks like M engines) started, since that factory opened (3, Munich), since S54s began production (2001ish), since some random day they chose (sneaky Germans), etc. In any case, 765 production days raises a red flag.
Since MZ3 VIN #049 had an S54 built on the 493rd production day, and MZ4 VIN #033 had an S54 built on the 765th production day, that means there's a difference of 272 engine production days for cars built 5 years apart. 272 working days is about a year and 2 months.
So...some scenarios:
1. Thousands of S54s have been sitting around for a few years in a warehouse (not likely).
2. S54s are not built every day. This means 272 days of S54 production spread out over 5 years. Doesn't make since, however, because an early S54 was built on day 493.
3. "Production day" lost something in translation and refers to something besides an 8 hour shift. Perhaps it means something more like "batch." Not likely since they refer to "day" quite insistently in this document.
4. It's a mixed production line, so engines with consecutive engine numbers aren't necessarily the same engine. For example, 61573765 is an S54, and 61583765 is an S85. Still doesn't make sense that there are only 272 engine production days between an '01 car and an '06 car.
Adds up to a great big
'06 M Coupe - Silver Gray/Sepang Brown Dark/Aluminum
E36 M3 - gone
E24 645 - gone
Old 01-08-2007, 02:34 PM
dwm's Avatar
dwm dwm is offline
I'm suggesting that what Ron has posted re. engine numbers may be obsolete, and that the last 4 digits are production day. Potentially relative to the first day of S50B30 (E36 M3) production. It matches up well with barnapkin arithmetic if we assume 260 work days a year. I don't have general assembly date for Ron's Z4M.
Dale: 04/2001 minus 2493 weekdays ~= September 1991
Dwayne: 05/2001 minus 2493 weekdays ~= October 1991
Dan: 06/2001 minus 2495 weekdays ~= November 1991
Al: 06/2001 minus 2514 weekdays ~= October 1991
Randy: 08/2001 minus 2554 weekdays ~= October 1991
JonM: 08/2001 minus 2557 weekdays ~= October 1991
Daniel: 12/2001 minus 2655 weekdays ~= October 1991
Ron: ??/2006 minus 3765 weekdays ~= ???
Daniel
2002 M roadster
Old 01-08-2007, 03:24 PM
matching revs in
Interesting. That document is dated 1990... You could be on to something.
E36 M3 - gone
E24 645 - gone
Old 01-08-2007, 03:32 PM
Ron Stygar's Avatar
19,585 Miles
Ron: ??/2006 minus 3765 weekdays ~= May 2006
May 2006
Old 01-08-2007, 07:32 PM
dwm's Avatar
dwm dwm is offline
So we get:
Dale: 04/2001 minus 2493 weekdays: roughly September 1991
Dwayne: 05/2001 minus 2493 weekdays: roughly October 1991
Dan: 06/2001 minus 2495 weekdays: roughly November 1991
Al: 06/2001 minus 2514 weekdays: roughly October 1991
Randy: 08/2001 minus 2554 weekdays: roughly October 1991
JonM: 08/2001 minus 2557 weekdays: roughly October 1991
Daniel: 12/2001 minus 2655 weekdays: roughly October 1991
Ron: 05/2006 minus 3765 weekdays: roughly November 1991
Just a theory, and nothing but circumstantial non-rigorous arithmetic and a miniscule sample size to support it. Pulled out of my you-know-what.
Daniel
2002 M roadster
Old 01-09-2007, 10:56 AM
struenz struenz is offline
Mein Auto: 99 Z3
I'll post mine next time I'm under the car, presumably next week.
Off topic, new jackstands arrived today, but I'm still waiting on the new floor jack. When it arrives, the carrier arm you sent me will go in, along with the shifter from Randy and final checkups before the HC voyage. I had a heck of a time finding someone to ship me a DK13HLQ before HC... apparently there's only one importer and they're waiting on a shipment. Steve (Ultimate Garage) had one in stock but only for pickup, ASE had none in stock and a lead time of several weeks, etc. Finally found All Tire Supply in TX had a few in stock and would ship on Thursday.
Any way you might make me a set of jackstand adapters for these if I sent you one of the posts? Or maybe you already have something that'll work? I know about your jackstands, I just really like the AC units and they were reasonably priced from Steve.
sorry to be off topic but where did you get those jackstands? found it..sorry
Old 10-04-2009, 05:24 PM
01 M Roadster 01 M Roadster is offline
Mein Auto: 01 M Roadster S54
My engine block has four lines of information and the last one being "Made in Germany". Would someone interpret these numbers for me and what they mean. Sorry, I'm new at this. My VIN LJ80334.
Engine Block:
326 S4 08A
0255 A 103
1100 0 304 353
Made in Germany
01 ///M Roadster S54
Old 10-04-2009, 06:49 PM
Ron Stygar's Avatar
19,585 Miles
Engine Block:
326 S4 08A
0255 A 103
1100 0 304 353
Made in Germany
Was that in the same engine place shown in our pics?
Looks like you got a replaced remanufactured engine in your car.
Did you just purchase the car?
Did you get the vehicle history from BMW dealer.
Old 10-04-2009, 07:47 PM
I did a second dive under the car to have a look again and found no other markings. "Yes" to your question whether that was in the same engine place shown in your pics.
I am the 4th owner. It was a private purchase from a geek working at HP who (in my humble opinion) bought as a status symbol to keep up with what other geeks were driving but had some difficulty driving a manual transmission.
According to the Carfax printout, he in turn purchased it from a used car dealer that got it from an auction, with I think was a front end damage. Before that, it seemed to be a company car for young preppies.
What do the ID numbers tell us?
Old 10-04-2009, 07:59 PM
Ron Stygar's Avatar
19,585 Miles
Don't know.
The part number is a remanufactured engine.
I asssume that the engine was changed sometime.
If you get a chance, take a pic of the numbers.
Try to get the vehicle history from a BMW dealer.
Old 10-05-2009, 03:52 PM
Don't know.
I can't seem to get hold of a service manager at the Weatherford BMW, Berkeley, CA to return my calls. I doubt if any of them would.
Here's what I got so thus far through research. Most of the listed engine casting numbers listed so far have 32 6 S4
in common. This I can safely assume that these codes corresponds with my 326 S4 08A on the first line of codes on my engine blocks' ID. I can only guess that the 08 is the month: August and the A: Exchange engine.
The second line of codes
: 0255 A 103, may translate to:
0255 = Serial Number each month
A = Exchange engine
10 = October production month
3 = 2003 production year
I don't know what the the third line of codes: 1100 0 304 353, mean.
Old 10-05-2009, 04:28 PM
Ron Stygar's Avatar
19,585 Miles
A = Exchange engine
11 00 0 304 353 is the part number for the remanufactured short engine as of 06/2003.
http://www.realoem.com/bmw/showparts...11&fg=05&hl=16
Old 10-05-2009, 08:18 PM
Thanks for the additional info, Ron.
Would you know whether a remanufactured engine resolves the rod bearing failure susceptibility issue?
Old 10-05-2009, 08:32 PM
Ron Stygar's Avatar
19,585 Miles
Yes. My guess is why they did the replacement.
You need to get the Vehicle History.
Old 10-07-2009, 06:48 AM
Here's my engine casting badge/branding:
I'm still working on getting the history from dealer.
Old 10-07-2009, 07:58 PM
Ron Stygar's Avatar
19,585 Miles
Wonder if there is data under the sticker?
Old 10-07-2009, 08:20 PM
i don't think so. i ran my finger by it to clear film of dust/dirt and it felt smooth. two things can happen:
(1) if there were engravings (such as in sample pic) underneath it, the heat cured the adhesive so much that it should have peeled off in parts by now -- adhesive doesn't stick very well on rough surfaces. or,
(2) if there were engravings underneath, the the heat cured the adhesive and sucked parts of the sticker into the grooves of the engravings.
none of the above happened.
i don't want to try peeling it off ... i won't be able to put it back and have it stick as good as it has up to now.
Old 10-07-2009, 08:24 PM
Ron Stygar's Avatar
19,585 Miles
The date circles above are gone too.
Old 10-08-2009, 04:58 AM
i noticed that too. remanufactured S54 engines were probably produced with some urgency to keep up with demand once BMW decided to replace them. keeping cost down would be another explanation for leaving out the date circles off.
if you're still curious whether there are engravings underneath the sticker, there would be telltale signs. see image below. i superimposed my image over the sample. notice that the sample's engravings go beyond the edges of the sticker.
Old 10-08-2009, 07:19 AM
Ron Stygar's Avatar
19,585 Miles
As a remanufactured, I took it as they removed it.
Old 01-05-2011, 07:32 PM
magnetic1 magnetic1 is offline
Mein Auto: 2001 Magnetic Red C5
Hey guys, bringing this back. Somehow came across this thread in my Googling of S54 block numbers.
Im currently building a 2004 E46 M3 racecar. In doing preventative pre-race work, I was in the middle of replacing the rod bearings when I noticed the rod bolts were M11. Since BMW doesnt even make M11 anymore and were replaced w/ the newer M10s and associated connecting rods, is it safe to assume that the motor in this car is a replacement engine from an earlier era?
My serial # is not stamped and is like 01 M Roadster's plate. It reads as follows:
32 6 S4 01A
0784 A 102
1100 7 831 914
MADE IN GERMAY
According to real oem, this motor part number is a reman from Up to 04/2003: http://www.realoem.com/bmw/showparts...=11&fg=05&hl=6
Oddly, there is NO history (at least not in BMW's system) that this 2004 M3 has ever had an engine replacement. The car itself has 90k miles on it.
Are my assumptions above correct?
Eric Wong
#199 IP/GTS3 M3
