Old 10-03-2007, 09:10 PM
orca4wd orca4wd is offline
Mein Auto: M Coupe
Bleeding Clutch Hydraulic System
I find this article to be interesting and was wonder if anyone tried it. Basically, using a trigger type oiling can to back flash the air bubbles without having to pump the pedal even once. It is a cheap and easy way done by one person.
http://www.bmpdesign.com/technical/t...eed_clutch.php
Any thoughts or comments?
Old 10-03-2007, 09:33 PM
Vinci Vinci is offline
DO IT YOURSELF.
Mein Auto: 98 M Roadster
The Motive pressure bleeder is pretty inexpensive and makes it a one-man job as well. It bleeds downward though. Great for flushing the system.
Old 10-05-2007, 04:49 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Clutch bleeder screw is at the bottom, so to use Motive bleeder you have to remove the slave cylinder and invert.
And the Motive adds micro bubbles to brake fluid, I don't use one any more.
The pump fluid from the bottom is how aircraft brakes are normaly bled, works quite well. And single person also.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 10-05-2007, 05:51 AM
Sands's Avatar
Sands Sands is offline
Mein Auto: 2000 M Coupe
The clutch system will "self bleed" to a certain extent. If you wait overnight, most of the air bubles in the MC will find their way out of the system. But as pinecone mentioned, the bleader on the slave is not at the top. You'll need to remove the slave to remove any air from that side.
Sands (aka Ian)
2000 M Coupe
Cosmo Black and no moon roof
IE Bushings all around, IE toe and camber kit
SS clutch line
VPD cooler cap & and a real Setrab cooler
Racetech pilot seat, schroth harnesses
Obey your Noodly Master! Ramen.
Old 10-05-2007, 05:52 AM
Sands's Avatar
Oh, if you do a 2 person or a pressure bleed, make sure the reservoir is filled above the feed tube to the clutch MC.
Sands (aka Ian)
2000 M Coupe
SS clutch line
Old 10-05-2007, 08:08 AM
rjcoston's Avatar
rjcoston rjcoston is offline
///M Practical
Mein Auto: 00 M Roadster
I think it's a good method but I would also flush the whole system at the same time.
http://www.bimmerfest.com/forums/sho...ighlight=bleed
Old 10-05-2007, 09:03 AM
DO IT YOURSELF.
I'm afraid I don't see how any pressure bleeder is adding bubbles to the fluid. It feeds the fluid into the reservior at fairly low pressure (~15psi) and then it settles in the reservoir before it ever enters the hydraulic lines.
I am going to be doing mine again this weekend to see if I can raise the pedal engagement point. It has been fairly low ever since I've owned the car, and I've never bled the slave off the transmission. It will be a good time to throw on the clutch line I've had sitting around too.
I'm going to see if I can use a c-clamp to compress the slave piston. I can't remember if there is suitable location on the back of the slave to clamp against, but I can rig something up.
Old 10-06-2007, 03:35 AM
Pinecone's Avatar
M Mad
Because the compressed air is in contact with the fluid and this forces air into the fluid.
Real pressure bleeders have a diaphragm between the fluid and the compressed air. And if you flush, it goes into the lines and calipers still under pressure which keeps the air entrained.
I have tried it over several iterations and I get a much firmer pedal doing it the old fashioned way, and get less fluid problems at the track. So have MANY other people.
If you use a pressure bleeder, it helps to NOT put fluid in the bleeder, just use it for air pressure. The reduced surface area contact with the compressed air reduces the effect.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 10-06-2007, 07:55 AM
Randy Forbes's Avatar
Investigative Tinkerer
Son of a gun! I've been using it that way because I hate cleaning the thing out after each use.
Back in the 70's, when I worked as a (REAL) gas station, they had a pressure bleeder with a diaphragm to separate the fluid/compressed air. I'm kind of surprised at the limited availability of a similar tool for the home-based mechanic; not that I've searched, but if I saw it, I probably would've bought one.
Randy Forbes
2001///M Rdstr Steel Gray
Old 10-07-2007, 06:13 AM
Pinecone's Avatar
M Mad
I have looked for one, and they are available, but pro version that cost a LOT.
I just have a friend come over or get my wife to help and do it the old fashioned way.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 10-07-2007, 11:29 AM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
KD 2222 is not too bad price-wise ($200 or less street price). The Branick G300 is nicer but almost double the price. I've seen the Branick in person, but not the KD. However, I suspect the KD would more than suffice for home use. The big difference is that Branick offers better adapter setups for master cylinder resrvoirs. But you can just steal the one from a Bavarian Autosport pressure bleeder.
For brakes, I've had good luck with speed bleeder valves in the stock calipers. I haven't put them in the Wilwoods yet. The ones I like are $15 each (306 stainless, dust caps included). http://www.speedbleeder.zoovy.com
Daniel
2002 M roadster
Old 10-07-2007, 02:18 PM
phrider's Avatar
phrider phrider is offline
Equine 1/4 miler ancestor
Mein Auto: 2001 M Roadster, 1998 M3
DWM, if you happen to recall, what size are our M Roadster stock bleeder valve screws?
Old 10-07-2007, 02:54 PM
dwm's Avatar
dwm dwm is offline
I think M7x1.0x35.15, but I'll check for you tomorrow since I think I still have some new ones somewhere. On my way out the door at the moment.
Daniel
2002 M roadster
Old 10-07-2007, 03:45 PM
Ron Stygar's Avatar
19,585 Miles
Z3 Brakes = M7x1.0--7mm hex
Z3 Slave = M6x1.0--7mm hex
Z4 Brakes = M8x1.25--9mm hex
Z4 Slave = M6x1.0--7mm hex
Old 10-07-2007, 03:48 PM
Ron Stygar's Avatar
19,585 Miles
A post from Josh over eight years ago
Old 11-11-2007, 03:34 PM
Donlundm3 Donlundm3 is offline
DonLundm3
Mein Auto: '01 MZ3
I just installed the UUC clutch line and did the following bleed procedure which worker fine.
1. After all lines in place and tight, I did 3-4 manual bleeds of the slave, i.e. opened bleeder and pushed brake pedal, closed bleeder, lifted pedel, until the old fluid wa gone, along with much of the air.
2. On the last push of the pedal with open bleeder, I left the pedal in the down position over night, a good 16 hours.
3. Came back next morning and slowly lifted the pedal back up.
4. It stayed up and worked perfectly. Slightly lighter feel to it than before, not as much back pressure or resistance, but that could be due to the line.
5. Drove it around and no issues. Wife likes the lighter feel.
I learned this procedure while rebuilding the brakes of an old motorcycle. Couldn't get all the air out no matter how much fluid I put through it. Was told to pull the brake lever as far as it would go, tie tit there and leave it over night. Did that, let it out the next morning and voila, brakes.
Old 11-11-2007, 06:06 PM
Ron Stygar's Avatar
19,585 Miles
Or air in the system.
Old 11-12-2007, 05:23 PM
DonLundm3
Mein Auto: '01 MZ3
Originally Posted by Ron Stygar View Post
Or air in the syatem.
You think? I didn't like the thought of trying to get the top nut back on the slave as my fingers aren't long enough to get at it and couldn't see how to do it. However, if, through your much more extensive experience than mine, you think that's the case, I guess I'll find a way to do it.
Old 11-12-2007, 06:01 PM
Or, you could leave it to me, as I'll have the undertray off (for the bearings) and have the BMW clutch bleeding tool.
Randy Forbes
Old 11-12-2007, 06:21 PM
DO IT YOURSELF.
+1 to that. If Randy is going to be under there anyhow, the BMW bleeder tool makes short work of a proper bleed. You can do it without one, but it's not elegant.
Old 11-12-2007, 06:38 PM
Ron Stygar's Avatar
19,585 Miles
That's what I would do.
Air compresses.
Old 11-13-2007, 06:20 PM
DonLundm3
Mein Auto: '01 MZ3
That will be done.
Old 08-04-2008, 08:45 PM
snowphun snowphun is offline
Mein Auto: WRX - 99 M Roadster
Bumping an old thread that's full of good info. The syringe method is intriguing, but I'm a bit confused: assuming there is some air in the slave, where does the air go with this method? It must be getting pushed into the hard line towards the MC? That appears to be a lot of line with a number of up and down bends where the air could get trapped?
Finally, where does one buy a 60cc syringe?
Thanks,
Paul
Old 08-04-2008, 09:17 PM
dwm's Avatar
dwm dwm is offline
Just buy the BMW slave cylinder bleeder tool. It works well and it's not difficult to remove and replace the slave cylinder.
Daniel
2002 M roadster
Old 08-04-2008, 09:19 PM
awdonald awdonald is offline
Mein Auto: 00 z3 m coupe
Last bleed" I used the oil can method...now a little off topic....and it worked great. I had a 12" (or so) clear plastic hose so could watch for bubbles (were'nt any). One man job.
