E36 (1991 - 1999)
Old 10-04-2007, 09:33 AM
carlos330 carlos330 is offline
Mein Auto: '93 325i
Need Assistance
Recently had my o2 sensor replaced but every morning i start the car the idle is very rough. After driving for a couple of blocks the check engine light comes on and the car begins to rev itself and i feel it pulling while my foot is on the break. Once i drive a bit longer the light goes away and it sometimes does the auto reving. Any ideas ?? Its a 325i with a slushbox
Old 10-04-2007, 10:18 AM
Mein Auto: '93 325i
anyone.....?
Old 10-04-2007, 11:38 AM
SCANDINAVIAN13 SCANDINAVIAN13 is offline
Resident Pilot
Mein Auto: BMW Not Found
You seriously waited only 45 minutes?
Come on. Please have a little more patience.
Sounds like a wet ECU to me. Perhaps a dirty ICV.
Kyle
1993 325is - Frigg - Grounded
2001 Z3 2.5 - Išunn - Active
Old 10-04-2007, 01:19 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Any codes being thrown??
You tried the pedal trick??
To run through the 4-digit code data on your car, put the key in the ignition and turn to the 2nd position, where all the cluster lights come on. Within a second, tap the accelerator pedal (fully) 5 times in rapid succession (total time about 3 seconds). The check-engine light will flash once and then turn off. It will then flash a certain number of times, turn off, flash another number of times and then do it twice more. If there are other codes it will then flash these. For example.... "flash... flashflash... flash... flashflashflash" would be a code of 1213 (whatever that is). If your car is telling you certain codes, you can crossreference these codes online and see if they mean anything's wrong. You will need to know the exact year and engine in your car when you search for a code list, as they differ by engine.
2001 Mini Cooper R50
Edirty6 for life
