E36 (1991 - 1999)
Old 10-04-2007, 09:59 AM
E36addict E36addict is offline
E36 " Perfection"
Mein Auto: E36,318is
Help with Rev counter needed ?
Help !
I have an issue with myRev counter.
It just doesnt seem to work , A while ago my rev counter and temp gauge stopped working.
So on to E bay I went and managed to ick up a replacement for next to nothing.
About an hour ago I fitted this new display and everything works apart from the Rev counter.
So the speedo works , the fuel gauge works , even the temp is now working but still the
Rev counter is dead .
Any ideas ?
cheers !
Old 10-04-2007, 11:39 AM
SCANDINAVIAN13 SCANDINAVIAN13 is offline
Resident Pilot
Mein Auto: BMW Not Found
Sounds like the sender isn't working. I'm not sure how to fix that, though.
For your own search reference, it's called a Tachometer.
A few searches using that should turn up some results.
Kyle
1993 325is - Frigg - Grounded
2001 Z3 2.5 - Išunn - Active
Old 10-04-2007, 06:11 PM
spoddy spoddy is offline
Mein Auto: BMW 320I e36 automatic
hi mate
same thing is wrong with my cluster, rev/mpg and temp gauges all not working.
fuel and speedo do work its really annoying, was gonna get a new cluster, but heard you get a red dot on the cluster and need to have mileage recoded.
i think the camshaft sensor needs replacing for the revs, try the pelicanparts site for explanation of doing this.
let me know how you get on.
Old 10-05-2007, 05:03 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Am 99% sure the revs dont work off the camshaft sensor buddy
This just checks the position of it to ensure the timing is correct
2001 Mini Cooper R50
Edirty6 for life
Old 10-05-2007, 02:41 PM
is it the crankshaft sensor?
i thought the camshaft sensor would sense the cams spinning round, and the faster they spin then the higher the needle goes?
or maybe its that awkard one under the thermostat housing above the geared wheel, dunno what is called.
i wouldn't mind knowing what does send the info to the dme or cluster.
so what controls the mpg dial?
cheers
Old 10-05-2007, 02:53 PM
Still here
Mein Auto: M3
The mph is worked off a vacuum mate
I will admit that i dont know for sure, but am sure the rpm runs off the coils or a related part
Edirty6 for life
Old 10-05-2007, 03:45 PM
so the crankshaft and camshaft have nothing to do with rpms.
aaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhh
how can i fix it then?
pirate whats happened? you don't know for sure? lol
does the mpg below the rpm work off a vacuum. so how can you fix the rpms, it doesn't sound right working off the ignition coils?
i dunno i'm lost.
Old 10-06-2007, 04:26 AM
does anyone know where exactly the vacuum thingy is
so I can check it out?
gonna take the cluster out and check soldered connections, any
thing else to look for?
cheers
Old 10-06-2007, 04:40 AM
Still here
Mein Auto: M3
Wait wait wait, i cant believe i made the mistake AGAIN!!
The mpg is NOT run off a vacuum, like i stated yesterday. I am sorry guys
It is calculated from the road speed, engine speed and fuel injection timing
Sorry
Edirty6 for life
Old 10-06-2007, 01:23 PM
so its a software thing then?
in the dme?
what components work together to make it all happen?
think i'll bring my cluster in and have a looksie
Old 10-06-2007, 02:05 PM
Still here
Mein Auto: M3
Yes buddy, the DME deals with it
Edirty6 for life
