E36 (1991 - 1999)
Old 10-04-2007, 12:57 PM
BLACKEDOUT95 BLACKEDOUT95 is offline
Mein Auto: 1995 325I
Another Person with a Central Locking problem
SO here goes...
I have to manually lock/unlock all of my doors and trunk. I just recently changed the central locking fuses (there are 3 of them) and all the locks seemed to be fixed...for about 2 days. The fuses blew out again and I have to go back to the manual locking/unlocking. What do you guys think it is? AND are there certain types of fuses I should be using for my car? Thanks guys....
Patrick
95 325I
Old 10-04-2007, 01:16 PM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Hey
You need to just use standard blade fuses buddy, just make sure they are the right rating. you can find this on the underside of the fuse lid
If they are correct and keep blowing then you have a short somewhere. Take off the door cards and look for damaged wires. Also check the wires under to bootlid as they are prone to wear and damage
2001 Mini Cooper R50
Edirty6 for life
Old 10-04-2007, 11:37 PM
BMW_tech's Avatar
BMW_tech BMW_tech is offline
Send a message via Yahoo to BMW_tech
Mein Auto: rickshaw
Originally Posted by BLACKEDOUT95 View Post
SO here goes...
Patrick
95 325I
Look for a set of wires to your trunklid,one or two of these wires may be shorting out when you open or close your trunklid blowing your fuses.I would trace the wires going to the trunk lock actuator.
YOUR SECRET ADMIRER
