Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
Z3 (1996-2002) and Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
Sirius: Z4 Coupes
Planning to do this mod this coming Winter keeping the CD changer.
Will also be doing the front and rear cameras and another to move around. Pricing on the right is dealer net. Sirius parts: Last edited by Ron Stygar; 05-17-2009 at 04:53 PM. |
What is wrong with getting a portable unit and using an Aux jack to get the sound?
Don't like cables showing. |
I thought the Aux Jack delivers less superior sound too. Integrated is the way to go.
- SuperSprint Race - OE STB - Dave Z Modified CDV - RE CS - H & R Sport - ZHP Shift Knob & Leather Z M Boot |
I am with you. I actually tried to have them throw it in while I was negotiating on the car, but was not successful. How much are they charging for the install? What dees the antenna look like? Another member here was saying that the antenna is not going to look like the factory shark fin antenna. This is why I am trying to decide on a portable unit.
Thanks. |
I'm told that the shark has the sirius antenna. Alan Alfano put me on to the mini shark on the E93 3 series convertible. If that works out, I will be putting it on the roof. Last edited by Ron Stygar; 11-03-2007 at 04:17 PM. |
Cool. Would you please post some pics when you are done?
Parts data
It's on the trunk lid for the E93.
Will take a pic of it next time I'm at the dealer. Last edited by Ron Stygar; 05-17-2009 at 04:55 PM. |
E93 info
![]() ![]() Last edited by Ron Stygar; 05-17-2009 at 04:56 PM. |
Parts ordered
Ordered the following:
Receiver 377 $495r Antenna 887 (in case shark antenna doesn't work) $39.99r Shark antenna 908 $149r Shark housing 674 $91.10r plus paint 6 Nuts 048 $0.62r $778.75r total All you need if installing the EAS way. http://www.europeanautosource.com/su...&root=23&id=41 Also ordered the EAS cable which lets it exist with the CD changer. $20 plus $9.75 shipping. http://www.europeanautosource.com/pr...roducts_id=235 Last edited by Ron Stygar; 11-08-2007 at 08:43 PM. |
E93 mini sirius antenna
E90 regular one is 7 inches long.
EAS cable (Sirius with CD changer)
Actually a BMW part 84 11 0 150 526 $15.10r / $9.82n
Mentioned in the X3 sirius instructions. Last edited by Ron Stygar; 05-17-2009 at 05:15 PM. |
Sirius advantage
![]() Last edited by Ron Stygar; 05-17-2009 at 05:16 PM. |
Can anyone confirm if the Sirius reciever works without Nav?
See post #1.
How does one access satellite mode without the Nav screen?
Same as with the NAV.
Sirius receiver and recommended antenna
Received the Sirius receiver and recommended antenna.
![]() ![]() Shark antenna should be here Wednesday. Looks like the bottom part of the antenna requires a ~ 2 inch x 4 inch oval hole. Not going to happen. Gave up on that idea. Thought about it and may be able to use the cover part #2 of the shark antenna with the recommended antenna. Will know for sure when it shows up. ![]() Last edited by Ron Stygar; 05-17-2009 at 05:25 PM. |
Shark Antenna plus
As mentioned, the antenna part of the shark antenna won't work.
The housing part with some mods will. The recommended antenna is magnetic and has a .040" double sided tape over it. Rather than usings the housing studs, I cut them off and will mount it with double sided tape. The recommended antenna fits the housing minus .020" on one side. Will mill the top off of the antenna cover until it hits the metal piece in the top of the antenna cover. Will drill one hole for the wire. ![]() ![]() ![]() Last edited by Ron Stygar; 05-17-2009 at 05:30 PM. |
Shark housing with no studs
Used ~.050" 3M VHB in dark gray to see how it fits with the contour.
Will modify the antenna tomorrow. Will install the system. If it works, will have the housing painted in white. ![]() Last edited by Ron Stygar; 05-17-2009 at 05:31 PM. |
Shark housing and antenna mods
![]() Last edited by Ron Stygar; 05-17-2009 at 05:33 PM. |
Trunks apart
Trunk will be apart for awhile.
Will probably velcro the Sirius receiver in place and ground it to the bracket. Have to finish the started insulation along with some other things this Winter. Last edited by Ron Stygar; 05-17-2009 at 05:35 PM. |
Install
Removed the amp bracket to add the velcro for the Sirius receiver.
CD changer wiring was available wiithout taking the front apart. Works fine with the CD changer (Just another input). Activated. Antenna temporary on roof. Shark cover makes no difference. Will drop off the Shark housing for paint. Hardest part of this will be locating the antenna dead nuts. Thanks to Tom of EAS for the how to and daisy chain cable which lets the CD changer exist with Sirius. Thanks to Alan Alfano for putting me on to the E93 mini shark antenna. Next. ![]() ![]() ![]() Last edited by Ron Stygar; 05-17-2009 at 05:36 PM. |
Antenna housing installed
I kind of like the antenna in black. Will be doing some body mods early next year and can change it to white if I change my mind.
![]() Last edited by Ron Stygar; 05-17-2009 at 05:38 PM. |
#25
Antenna housing in body color
Mirror helped a lot positioning it. Last edited by Ron Stygar; 05-29-2010 at 10:58 AM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
