Disable brake pad sensors? - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 10-05-2007, 10:50 AM
OSUbeaverFan's Avatar
OSUbeaverFan OSUbeaverFan is offline
Mein Auto: 2005 F150 King Ranch SC
Anyone know a quick and easy way to disable the brake pad sensor? I am trading my car in today and the brake pad sensor just came on. I just change the brake pads last month, but didn't change the sensors (I know I am cheap!). I just took the brake sensor off and the warning light is still on! Thanks!
Jason
2005 Ford F150 King Ranch Super Crew
2000 BMW 328i (Sold 10/2007)
2000 GMC YukonXL (wifey's gas guzzler)
Old 10-05-2007, 10:59 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Cut the wire just above the sensor, strip the insulation back, and jump the two wires together to complete the circuit.
Regards,
Bob
Old 10-05-2007, 11:02 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
...then turn the key do the ON position (but don't start the car) for 30 seconds to get the light to shut off.
Old 10-05-2007, 11:04 AM
wag-zhp's Avatar
wag-zhp wag-zhp is offline
Mein Auto: 97 White 328iC
And then be ethical and be sure to tell the new owner about what you did.
When it absolutely, positively, has to be destroyed overnight! OohRaah!!!
U. S. M. C.
Semper Fidelis
Old 10-05-2007, 11:21 AM
Absolutely!
Do I keep the wires the together after I strip them, i.e. tie them together?
Right now I have them tied together, did the ON thing for 30-secs, but the light is still on. I did both the front and rear.
Jason
Old 10-05-2007, 11:22 AM
Never mind! It worked! I am a dumb ass!
Thanks for your help!
Jason
Old 10-24-2007, 07:46 PM
ckleung100 ckleung100 is offline
Mein Auto: '99 323i
So why would the sensor suddenly turn on one month after pads were changed? If they had been worn out before the pad change the light would have been on all the time.
Old 10-25-2007, 04:20 AM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
It won't.
The sensor wore through on the old set of pads and he never replaced it. Once it wears through, it must be replaced. Fitting new pads wont turn it off.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
