Old 10-05-2007, 01:35 PM
jtm964's Avatar
jtm964 jtm964 is offline
Mein Auto: Z4M Coupe, X5 3.0, 986S
MZ4: Engine rattling noise
Have a question regarding the Z4M engine.. I noticed there is some kind of slight rattling/vibration inside the engine when the RPM is around 3000 to 3500. Once it rev past that zone, the vibration is gone. Anyone has an idea what that maybe? Appreciated.
Old 10-05-2007, 08:25 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
I know the Z3 engines are know for a "vanos" rattle. Fix is to replace the vanos solenoid.
I guess it maybe something that they still have not fixed.
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 10-05-2007, 08:28 PM
Ron Stygar's Avatar
19,585 Miles
Do a search using
vanos noise
Old 10-05-2007, 08:30 PM
BMW_tech's Avatar
BMW_tech BMW_tech is offline
Send a message via Yahoo to BMW_tech
Mein Auto: rickshaw
have someone rev it to where the noise is present and try to locate where it is originating from.if front around vanos,its vanos.if lower than vanos,its the chain tensioner.im sure you keep your vehicle well maintained and changes the oil on time.
YOUR SECRET ADMIRER
Old 10-06-2007, 01:44 PM
jtm964's Avatar
Thanks...
yes its well maintained... only have 3000 miles and oil was changed at 1200 miles
Old 10-06-2007, 04:16 PM
nhs156 nhs156 is offline
Mein Auto: '10 M5
It is the VANOS - there's a BMW service advisory out that say it's normal. Saw it here or some other site. That said, the dealer replaced mine at 5500 miles as it was "too noisy" (causing dash rattles). Go figure...
Old 10-06-2007, 04:59 PM
BMW_tech's Avatar
Mein Auto: rickshaw
I had a tech that replaced one after an advisement from a Field Service Engineer and did not cure the noise problem.After I was asked for an opinion I grabbed my stethoscope and found the noise lower than the replaced VANOS.I then removed the chain tensioner and found it easy to collapse by squeezing it.Replaced the tensioner,and the noise was gone.The noise was caused by the slack on the chain,no damage will/was ever caused by previous experiences with timing chains.Hydraulic tensioners can collapse due to restrictions in oil flow,much like the lifters.Regular oil changes should be adhered to in preventing sludge formation or contamination especially the weekend drivers.Daily drivers often experience this when it reaches high mileage due to engine oil services becoming too frequent and exceeds service interval before performing/taking action.
The newer it is and the more we baby it.The older it gets,the less one cares.There is no happy medium,just plain common sense in maintenance and vehicle condition.
YOUR SECRET ADMIRER
Old 01-06-2013, 08:00 AM
nitrydr1600 nitrydr1600 is offline
Mein Auto: 1997 z3, 1982 corvette
is that common for a 97 1.9 engine also? i have 1 that sounds like a rattle around the chain but not sure if it could be a tensioner
Old 01-08-2013, 10:32 AM
changed the tensioner and still have the rattle??????? any ideas. seem to keep getting knock sensor codes 300 and 325
