1988 528e Will Not Start - Bimmerfest - BMW Forums
E28 (1982 - 1988)
Old 11-04-2007, 02:57 PM
bloodniece bloodniece is offline
Mein Auto: 1986 528e and 1988 528e
My girlfriend was driving down the road when the car stalled. She coasted into a lot and tried to start it back up but it wouldn't turn over. You can hear the starter turning, I can hear the fuel pump in the trunk, but it just won't turn over. We checked the fuses and battery and both are fine. We even tried using jumper cables for the heck of it. Any ideas?
p.s. oh yeah, there is a half a tank of gas.
D
Old 11-05-2007, 09:53 AM
More info:
She said the car smelled like gas for the past month. Fuel filter? Charcoal cannister?
Old 11-05-2007, 09:59 AM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
Probably a bad fuel line at that age. Follow the smell.
Old 11-05-2007, 01:01 PM
more info
I pulled the fuel line to the fuel pressure regulator and turned it over, boy did it pump out fuel! Does that mean the fuel rail is getting proper fuel? There was oil coating the main hose to the air intake though.
I replaced all the plugs since they looked pretty caked with corrosion. still, nothing.
Old 11-05-2007, 01:02 PM
Banned
Mein Auto:
Thats a good indication.
Now check for spark.
Old 11-05-2007, 05:21 PM
Sparkhttp://forums.bimmerworld.com/
Pulled a plug and turned it over and got a good spark.
Old 11-05-2007, 07:02 PM
Banned
Mein Auto:
If a you have a compression gauge, that will rule out internal damage.
Next is to start checking resistance values on O2 sensor, AFM, Coolant temp. Probably need manual for this stuff.
HTML code is Off
