Old 03-17-2003, 09:23 AM
alpina22's Avatar
alpina22 alpina22 is offline
Registered ABUSER!
Mein Auto: 2001 M Coupe
AndyM: Did you complete the ICE?
Maybe I missed your post but I was wondering if you ever completed the stereo installation? I think I have practically every ICE upgrade post bookmarked but am anxiously awaiting to see what you decided upon.
Cheers
Alpina22
00=oo=00
Old 03-17-2003, 09:31 AM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
He's finished. Everything is in his car except for mp3 player.
I'm in the middle of mine now.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 03-17-2003, 10:25 AM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
Finished the stereo upgrade a while ago. No creaks, rattles or any sort of regrets. It performs better than what I was expecting and I doubt I would go another way. Curious if JonM is actually documenting the install in his car, wouldn't blame him if he isn't though.
Old 03-17-2003, 10:46 AM
JonM's Avatar
Moderator
Not documenting. I am tired of documenting every little thing.
I wonder about using 2 JL 6W0's. The second could go in a leather-covered box in driver's side aft corner of hatch. Not sure I want the weight and hassle trade off however.
Jon Maddux
Old 03-17-2003, 10:56 AM
chazzy chazzy is offline
Mein Auto: '01 M Coupe
I love my single 6W0 and would love to add a second one. I thought hard about adding a second one exactly where you described -- in a small wedge shaped box in the lower left corner (mine would have been a fiberglass box, carpeted), especially since I had a fourth channel on my amp that was doing nothing at all. The problem is that it's a totally different box from my existing box. My current one is the OEM HK, ported, and rear facing. The other one would be custom, sealed, and forward facing (mostly). If it wasn't so much work to build an MDF-fiberglass box, I probably would try it anyway, since I really like the 6" over the other sizes (10" is the other stuff that I use). If I really have some time over this summer, I might build one just to find out. I really like the fact that I don't need to remove the sub for auto-x, so having to remove the second one periodically is a downside because it wouldn't be as secure as the existing bolted one.
BTW, what did you guys end up putting in? Photos and docs aren't required -- just a list is fine.
Old 03-17-2003, 11:02 AM
AndyM's Avatar
Suede Master
We both went with:
JL Audio 300.4 Power Amp to drive 4 corners
Kenwood KAC-5201 or KAC-529S Power Amp, bridged, to drive sub only
Boston Pro 5.5 front component speakers
JL Audio XR525-CSi rear component speakers
JL Audio 6W0 Subwoofer, 4 ohm model
Old 03-17-2003, 01:02 PM
Nice job. If it's anything like mine, I'm sure you're just as happy with the results as I am. Understated and neatly tucked away are the operative words.
Old 03-17-2003, 08:31 PM
Daver Daver is offline
Shake well
Mein Auto: 2003 325iT
Have you seen/heard of the Rockford Fosgate OmniFi? Hard-disk based MP3 player that syncs up with your home computers via 802.11b.
AudioWorld article about the OmniFi
I believe it can be hooked up via line-level RCA cables or using an FM adapter... biggest problem I see is the wired control panel. There's just not a lot of good places to mount something like that in a Z3.
Also, JVC has a 12-disc CD changer (JVC CH-X1500, CD-R/MP3 capable), but I'm not sure if it'd work with my current JVC headunit though.
daver -- 2003 325iT
Old 03-17-2003, 09:14 PM
AndyM's Avatar
Suede Master
Also, JVC has a 12-disc CD changer (JVC CH-X1500, CD-R/MP3 capable), but I'm not sure if it will work with my head-unit. Not sure if it'd work with my current JVC headunit though.
If JonM has success with the iPod, I will go that route. Nice small remote, nice small unit and being portable, it can go anywhere when not in the car (not like I spend alot of time in the coupe as it is). Been thinking about getting one to pass the down time while at Northland (these 12 hour days suck ). Changer is out as I am not willing to mount one in the trunk area (went through a lot of trouble to keep the car as stock looking as possible from behind the seats and back). If the iPod does not work out, will stick with one cd at a time.
Old 03-18-2003, 06:15 AM
Dr. Phil's Avatar
Dr. Phil Dr. Phil is offline
The Original Dr. Phil
Send a message via AIM to Dr. Phil
Mein Auto: 2012 135 coupe
Originally posted by AndyM
We both went with:
Curious as to your placement of the 6W0 I dearly want to add a little bass to the xiT without a lot of space loss or looking out of place affect
I know completely different cars but you never know
2012 X5 Premium, Sparkling Bronze/Sand/lLight Poplar, Premium Sound, 20 Way Seats, Head Up, Comvenience, Surround View, Sirius, Heated Seats
Old 03-18-2003, 07:10 AM
AndyM's Avatar
Suede Master
The 6W0 fit in the stock sub-enclosure on the coupe.
Connect to (original Stereo post):X-mas Project
Sub installed:
Finished result:
Old 03-18-2003, 07:15 AM
Dr. Phil's Avatar
As you know the wagons do not have one of those locations but the size might allow for it to be hidden somewhere reasonable. I will investigate
Old 03-18-2003, 10:40 AM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
Phil, I'm still waiting for someone to sell off a sedan HK system (I am doing a partial retrofit) but to go with that it's looking like a small sealed-box sub like a 6w0 (I have a Kicker S8b sitting around) will work in what's being called a 'sonotube sub' enclosure that will easily drop into the middle of the spare tire.
Put that term into google and you'll see what I'm getting at.
Old 03-18-2003, 12:00 PM
Dr. Phil's Avatar
Hmmm............interesting
Keep us in the loop on your process. I did look at 6W0 ealier but JL only sells a 3 piece enclosure which sort of defeats the space issue. I need to track down my previous installer and get his input on a single set up and discuss the sonotube idea
Old 03-19-2003, 09:16 AM
alpina22's Avatar
Registered ABUSER!
Thanks for sharing the info as always. Love the stock look of it all.
Alpina22
00=oo=00
Old 03-26-2003, 03:59 PM
Adam12Hicks's Avatar
Adam12Hicks Adam12Hicks is offline
Send a message via AIM to Adam12Hicks Send a message via Yahoo to Adam12Hicks
Mein Auto: 06 Sapph Blk M Roadster
Exclamation As far as that OmniFi goes...
You guys might have overlooked a seriously cool point. If that OmniFi is 802.11b wireless, I will be able to manage the song library in my car from my office, wirelessly. Just turn the key in the car to ACC for a few minutes and transfer music from my laptop, etc.
This is the direction of cool things nerdy, such as the Bluetooth wireless kit for my new 3 series. Being able to use speaker phone, caller ID on the radio, view address book on the radio, etc WHILE THE PHONE IS IN MY LAPTOP BAG IN THE TRUNK! is the coolest thing since sliced bread to me.
Wireless is getting cooler and cooler by the month!
Adam
2006 Z4 M Roadster
2005 X5 Kid Truckster
1991 318is e30 Play Car
Old 03-27-2003, 08:02 AM
DannO's Avatar
DannO DannO is offline
Mein Auto: //M Coupes
Re: As far as that OmniFi goes...
BOING!
