Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 10-07-2007, 01:07 PM
colorplates colorplates is offline
Mein Auto: 1988 BMW 528e
Fuse-o-rama Drama
Hi there,
I am trying to get some answers about a problem I am having. My fuel pump shuts down while driving from time to time, rendering me immobile. I am pretty sure the problem is electrical in nature as I found a temporary solution which is to pull another 8 amp fuse out. If I have all the fuses in correctly, the fuel pump shuts off after a while. When I pull an 8 amp fuse, it starts up just fine. Is there a simple solution to this issue? I have replaced all the fuses with new ones and made sure they are getting good contact.
I would like to have use of all the electricals and hope I am not damaging something by running it without the fuse.
-D
1988 528e
Old 11-11-2007, 06:13 AM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
Replace the fuel pump relay and if you haven't yet, the main relay also.
Jimmy Moreno
1995 530i
1986 535i
HTML code is Off
