E46 (1999 - 2006)
Old 10-10-2007, 10:23 AM
chefman chefman is offline
Mein Auto: BMW 323ci 2000
Red face OBDII Connector inside cabin under dash - MISSING?
I have a 2000 323ci. Getting ready to purchase the Autoxray Code Reader SC-1500. Verified with manufacturer that it will in fact work with BMW cars 1996 or more recent. I know where the OBD "trap door" is under the steering column, where you plug the interface cable to the scan tool, BUT, when I open the trap door cover I can not feel or see any kind of connector in there at all. Checked by feeling around and looking with flashlight, but I can not see any OBD socket whatsoever. I am willing to unscrew everything in that general area to see if perhaps the socket is in there somewhere (perhaps it came loose and needs to be relocated back into position), BUT, before I start doing that and waste my time tearing the dash apart, I wanted to check if by any chance, this particular car does not have an OBD2 socket in there at all. Has anyone out there accessed the OBD connecter under the dash that I am talking about or is the OBD located under the hood (the round one) the only interface socket on this particular car? Any guidance appreciated Mark
Old 10-10-2007, 10:36 AM
crowz's Avatar
crowz crowz is offline
Mein Auto: '00 323i/97 528i/94 318is
Its suposed to be located in the trap door thing your talking about. If it isnt I imagine it was taken loose during a repair and not put back in the right spot. It should be in there somewhere so yep its time to explore some
Old 10-10-2007, 12:11 PM
Mr Paddle.Shift Mr Paddle.Shift is offline
Mein Auto: bmw
I have a feel the round 20-pin connector under the hood is the only one. On 2001 and on, they used the 16pin under the dash.
Technik Engineering ASA Stage 1 Supercharged E46 M54B25.
NASA TTD So Cal. Track blog: VSETrack
Old 10-10-2007, 01:02 PM
crowz's Avatar
Ive got a 2000 and it has both connectors. The one under the dash and the one under the hood so yes the one under the dash should be there.
Old 10-10-2007, 01:15 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
I don't think that's the case, since 1996 it's been US law that all cars have a ODB2 connector. I think BMWs up to and including 2000 had both.
Old 10-10-2007, 01:36 PM
crowz's Avatar
The connector under the hood is for programming the car. The diag port is the one under the dash.
Old 10-10-2007, 01:57 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Well, a certain amount of diagnosing can be done via ODB2 too - diagnostic is the D in ODB . BMW would only pass off enough diagnostics down to the ODB port to be legally ODB compliant.
Old 10-10-2007, 02:14 PM
Many thanks to all for the advice on this. I will dis-assemble the panel underneath the steering column and see if I can find the OBD socket 'floating' around in there somewhere. I agree with the posts that there certainly should be an OBDII connector in there as the car is a year 2000 model and anything younger than 1996 was mandated to be equipped with an easily accessible OBDII in the cabin. This was my first post on this forum, great sense of community here, and I look forward to giving back anytime I can help someone else out. Thanks again! Mark
Old 10-12-2007, 05:20 PM
spazmataz's Avatar
spazmataz spazmataz is offline
Mein Auto: 2002 318i m-sport 5 spd!
did you find it? i have the same car as you and it should be there... i have both too!! would be weird if you didnt have one.
Old 12-04-2014, 01:45 PM
what'sinaname? what'sinaname? is offline
Mein Auto: 1999 328i
I have a 99 e-46 328i and I can't locate any connector under the driver's side dash- just the big, round one under the hood
Edit: The OBD Clearinghouse site has actual photos showing where to locate the port.
Old 12-04-2014, 02:30 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Two items of note:
1. You are responding to a thread from over seven years ago. In the future, check the dates before posting....it`s usually better to just start a new thread stating your issue in the thread`s title. You will get the most up-to-date info with that method.
2. As KrisL stated, Federal law mandated that all US=production cars be equipped with OBD connections. Unless somebody removed yours, it`s probably tucked away under there some place.
The road goes ever onward....
(R.I.P. Jever)
Old 12-04-2014, 02:45 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & JB4+ 335i
Two items of note:
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 12-04-2014, 03:21 PM
Two items of note:
Did you read my post before mashing the submit button, Bobbo?
1. Yes, I KNOW it's 7 years old. I'm familiar with how message boards work.
And I've also seen you get your panties in a bunch with people who start new threads rather than use the search function to find existing threads (how do you think I found this thread in the first place?)
2. I added new information in my edit which brings more up to date information to this thread than any of the other threads that the search function turned up had in them. I guess that escaped your eagle-eye, or maybe your moderator cap has gotten a little too tight, whatever.
3. It's just a message board- lighten up
Old 12-04-2014, 04:07 PM
TheMalibuMafia
It's probably just pushed up into where it's suppose to go. I would remove the plastic cover under the steering wheel and take a look. It's two screws and 2 clips, very easy to remove.
TheMalibuMafia.com
