E30 (1982 - 1993)
Old 10-14-2007, 10:35 AM
mlizzi mlizzi is offline
Mein Auto: 325e
325e engine surge
Help
I just replaced my air flow sensor, and the car is surging when warm and idling.
Do these units need adjusting?
Any suggestions?
THANKS
Old 10-14-2007, 10:40 AM
downhiller's Avatar
livin large
how bad is it surging? is it just have this surge at idle or through the whole rpm range?
Old 10-14-2007, 11:32 AM
Mein Auto: 325e
The surging only happens when it is warm and when idling. it surges in the 7000 to 12000 range so not that bad
Old 10-14-2007, 11:45 AM
downhiller's Avatar
livin large
check out this thread and it might lead you to some possiblities
http://www.bimmerfest.com/forums/sho...d.php?t=230684
and even if you dont find the problem youll be fine, thats not a huge difference in rpms. just kinda kills the gas mileage.
Old 10-14-2007, 01:11 PM
Mein Auto: 325e
Thanks downhiller!!!!!!!!!!!
Old 10-14-2007, 01:42 PM
Mein Auto: 325e
Downhiller
One more question for ya. The air flow sensor that I bought was from a junkyard. It is running much better than before. Could the surging still be a problem with the air flow sensor.
I will probably get a machanic look at it
Old 10-14-2007, 03:25 PM
downhiller's Avatar
livin large
its hard to say, it could be and then it could be something else. a simple way is to start with the obvious. check the filters (air and fuel), make sure there up to speed, then go to the sensors (check the o2 sensors too), clean the connectors with an electrical cleaner for better continuity, then if that doesnt do the trick then you need to start looking at new sensors, or slightly used one. and after that it goes in to the ICU, ICM, and ICV.
but taking it to a mechanic is a good idea so they could connect their computer in and they can see what is sending a good signal and which have weak signals.
Old 10-15-2007, 06:40 AM
AdamAnt's Avatar
AdamAnt AdamAnt is offline
Go Fast
Send a message via MSN to AdamAnt
Mein Auto: 1986 325e
you probably got a crappy AFM, take it back and try another one.
