E30 (1982 - 1993)
Old 10-17-2007, 09:26 PM
kamotors's Avatar
kamotors kamotors is offline
Mein Auto: 325i
Unhappy drain bolt
my drain bolt leaks...ive changes the bolt and the washer and it still leaks.....added a little bit of stop leak(dont want to kill my car)which slowed the leak. do i need a new oil pan? if so i think ill just let it leak...its not that bad of a leak
89 325i~~04 s60r~~88 635csi~~91 325ix-SOLD~~02 WRX-SOLD~~04 WRX-SOLD~~01 2.5RS W/h6-SOLD
Old 10-17-2007, 09:39 PM
rtwaits rtwaits is offline
Mein Auto: 1991 325i Convertible
Oil Leak
Did you tighten the bolt to 24 ft-lb? Is it over tghtened? Is there something on the threads (like teflontape) that may help? But not contaminate the oil
Old 10-17-2007, 10:01 PM
downhiller's Avatar
livin large
drill and tap or drill and heli-coil, simple fixes, hold good, but not a permanent fix. plus you might need a new drain plug and a quart of 5w-20 to get some of the shaving out.
i know ive done this a few times on VWs and audis.
Old 10-18-2007, 08:24 AM
kamotors's Avatar
Mein Auto: 325i
yes its tightened to 24lbs....ill try teflon tape
