Old 10-21-2007, 07:30 PM
cn90 cn90 is offline
Align Front Wheels Yourself After Tie Rods Replacement
Hi,
I just want to share this little trick to save you $70-80 on Alignment cost after Tie Rods replacement. This is trick on my 98 Volvo V70 but the idea is true for many cars, E39 included.
My OUTER Tie Rods have some play so I decided to replace them (The INNER Tie Rods are still OK @ 83K).
ASSUMPTIONS:
1. Front Tires same brand and wear is the same between R and L sides.
2. All tires pressure at mfg recommended level, I use 38 psi.
3. Car's alignment is 'perfect' before Tie Rods replacement, i.e. recent aligment was done or car runs in straight line on highway (I know this is not really scientific but close......)
For Details of INNER and OUTER Tie Rods, search the forum.
My Tricks:
1. Keep Steering Wheel Straight
2. Park in a Flat Garage.
3. Use a Carpenter Square and Masking Tape, mark the Equator of the Tires where the Carpenter Level is flat, as shown in picture.
Depending on car model, you may need to use a piece of wood or something on the body panel so the REAR of the Carpenter Square is resting on a Fixed Part (Body Panel).
4. Record the distance between the Wheel Rim (make sure there is no curbside damage at where you measure) and the carpenter square (which is held at the Equator's Level), be careful to make a diagram so it is accurate between Wheel's Front and Back values and R vs L (do not get confused!!).
5. Install new OUTER Tie Rods using DIY you find elsewhere.
6. You may need to roll the car forward and backward 2-3 inches to remove any flat spot when you lower the car after installing the wheels.
But make sure you do not drive it more than 2-3 inches. Bring it back to the same original place in the garage. Use chalk to mark garage floor if necessary.
7. Periodically check the Steering Wheel to be sure it is still straight.
8. Restore the R and L Wheel Rim Values as "original".
9. Once happy, do NOT forget to tighten the lock nut on the INNER Tie Rods.
10. Test Drive the car and it should be dead straight on the highway!
You just saved $70-80 for some beers.....
Again this assumes that the car's alignment was 'perfect' beforehand.
Otherwise, if the above procedure fails, then go for Alignment. But you have to stop drinking beers for one month!!!!!!!
Hope you guys find this useful for the cars that you own. Not scientific but very close and to my surprise it is dead straight on the highway after my Tie Rod job!
cn90
98 BMW 528i 96K miles
98 V70 83K miles
Old 10-21-2007, 10:28 PM
Eddie Bimmer's Avatar
Eddie Bimmer Eddie Bimmer is offline
Mein Auto: X5
I've used this and marked the laser dots on the wall. The further you are from the wall, the more accurate it gets. It's a piece of cake, actually.
Old 10-22-2007, 08:05 AM
The laser carpenter level idea is brilliant! But only works if you do not move the car one inch!
The problem is, when raising the lowering the car, it moves sideway a bit (not much but a bit).
My technique relies solely on the car's body panel, so it is not affected by the little movement associated with raising and lowering the car.
So far so good, car is dead straight as new!
Old 10-22-2007, 11:43 AM
tomibriggs's Avatar
tomibriggs tomibriggs is offline
Mein Auto: 1997 BMW 528i
I haven't had an alignment since I replaced the shocks & springs on my car but my car drives straight on the freeway. Will this procedure apply?
My steering wheel is not straight/aligned though so I cannot rely on that. Any alternative for trick #1?
Old 10-22-2007, 12:45 PM
My technique has its own limitation
Assuming your car's alignment is good, and if steering wheel is not straight, then do this:
Mark the INNER Tie Rod with black marker.
Turn the INNER Tie Rod the same amount for both side: let's say to drive straight on the hwy the steering wheel is rotates a bit toward the R. See Picture a.
So when straightening the SW, the Front rims now point slightly (1-2 mm) to the L.
See Picture b.
So if you:
-Toe-in the L side a bit (maybe a 90 to 180 turn of the Inner Tie Rod)
-Toe-out the R side a bit (maybe a 90 to 180 turn of the Inner Tie Rod)
Final Result is Picture c.
Make careful notes of the original setup and count how many degrees you roate the INNER Tie Rods. Turn the same amount for both sides.
Then tighten the lock Nuts.
Test drive it. You may have to adjust a bit more by trial and error.
In my Honda Odyssey van, they aligned the car after transmission work but the steering wheel rotates a bit to the R when cruising on hwy; I know it drives straight but the SW rotating a bit to thr R was annoying. I adjusted it about 180 degree twist on the INNER Tie Rod. All is fine and the SW is dead straight.
Since you did spring, shocks etc, I think you are better off with a proper wheel alignment at the shop.
Old 10-23-2007, 10:35 AM
e39dream's Avatar
e39dream e39dream is offline
L C B
Mein Auto: 1998 528i sport, DOB 5/28
if the wheel is as seen in the upper left of your illustration while going straight could/ would that cause excessive inner tire wear of the front tires?
Old 10-23-2007, 07:07 PM
Actually in the UPPER Left pic: the car goes straight, wheels are perfectly aligned, it is just the steering wheel not set at center: annoying but no issue.
On the contrary, sometimes the SW is set straight but the wheels are mis-aligned.
Where the SW points to has nothing to do with wheel alignment.
Old 07-01-2008, 11:41 AM
Test_Engineer's Avatar
Test_Engineer Test_Engineer is offline
Drives cars for a living!
Mein Auto: 2011 BMW 335i
Typically if you are replacing a worn suspension part that locates the knuckle(tie rod, lower control arm....), your "BEFORE" measurements will be out of alignment due to the worn part you are replacing. So by using this method, you are essentially putting the car back to a poor alignment condition it was in before you changed the part. Doesn't make much sense to do that.
Old 08-20-2012, 10:35 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
May I ask the simple (possibly loaded) question of what ACCURACY is 'needed' for a home front toe alignment for the E39?
BMW specifies 10' in the Bentleys (specifically from -05' to 015') given the front total toe spec below of 05' 10'.
I must admit, I've never measured anything to a degree, let alone to ten minutes; so may I ask what may be obvious to others:
Q: What accuracy is 'needed' for a front toe alignment for our E39?
Old 08-20-2012, 01:17 PM
Fudman's Avatar
Fudman Fudman is offline
See Section 4.3 and 7.1 of this: http://www.howtopdf.com/?zV9cFDPQ
Now this is per BMW. Can you feel differences at those tolerances? Doubtful. Will your tires wear differently at those tolerances? Maybe.
Old 08-21-2012, 05:05 AM
shaftdrive's Avatar
shaftdrive shaftdrive is offline
Matching beemer & bimmer
Mein Auto: 1999 K1200 & 2001 525
That links took me a few tries and resolved to bimmerboard.com members snitch740i original BMW_Wheel_Alignment_Systems[1].pdf
1170 views Original Link: http://www.bimmerboard.com/members/s...tem%5B1%5D.pdf
Code:
7.1 Measuring options
An overview of all measuring options and values (VA = front axle, HA = rear axle) is shown below.
Measuring options Measuring accuracy In measuring range Total measuring range
Total wheel toe (VA + HA)  2'  2  18
Single wheel toe (VA + HA)  2'  2  9
Camber (VA + HA)  1'  3  10
Wheel displacement (VA)  2'  2  9
Geometrical drive axis  2'  2  9
Castor  4'  18  22
Kingpin inclination  4'  18  22
Toe-differential angle  4'  20  20
Maximum steering angle (VA )  4'  60  300
Maximum steering angle (HA )  4'  9  9
Castor correction range  4'  7  10
Note:
The measuring accuracy details only apply when using the precision rotating and sliding plates as well as
the BMW quick-acting clamps.
Old 08-21-2012, 11:18 AM
bluebee's Avatar
I took the liberty of attaching the document Fudman kindly referenced.
I asked in the philosophical thread what the 'claimed' accuracy is of the BMW alignment tools, based on that document.
But I'm confused by the information in that document.
Q: What do these columns actually indicate with respect to accuracy for rear camber and for front/rear toe?
See also:
- Which of the dozen alignment specs are adjustable on the BMW E39 (1) (pdf) & cn90's front alignment DIY (1) (2) and cn90's rear wheel alignment DIY (1) & what tools measure rear camber at home (1) (2) and what tools measure front/rear toe at home (1) & what tools lock the steering wheel & brake pedal at home (1) & why does BMW recommend weights to set the normal ride height (aka nominal suspension position) prior to any alignment (1) & how to diagnose uneven tire wear on the inside edge due to camber and toe alignment issues (1) (2) & how to select a replacement tire strictly by the numbers (1) & what are the most common bimmerfest user's tire recommendations (1) & where do people buy their tyres anyway (1) & how many miles do you get for every 100 UTQG points (1) & what are the recommended tire pressures for front and rear (1) & what are the claimed benefits of nitrogen gas (1) what tire mounting tools do you need to change your own tyres at home (1) (2) (3) & where are the match mounting marks on the wheel and on the tire for precise tire mounting based on radial runout and heavy spot considerations (1) & what tools do you need to balance a wheel at home to eliminate shimmy or vibration at speed (1) & how do you properly dispose of your old worn out car tires (1) & how to measure bent wheel dimensions such as rim runout and wheel eccentricity at home (1) & where to get bent or damaged wheel rims repaired (1) (2) & what winter driving ice and snow tire chains to use (1) & what are the most recommended products for cleaning BMW BBS wheels (1) & where to buy E39 wheels online (1) & what are the main causes of vibration while highway driving (1) & vibration while highway braking (1) & how to diagnose a violent shudder while slow speed braking on bumps (1)
Old 08-21-2012, 12:16 PM
Fudman's Avatar
BB:
"With respect to accuracy for rear camber and front/rear toe",
The required accuracy of the measuring system is column 1 of Table 7.1
That accuracy must be held within the range specified in column 2 of Table 7.1
The required tolerance of the specification is the =/- value in the Bentley Table.
The table you attached from Bentleys are the actual alignment specifications for the e39. These specs are within the ranges specified in Table 7.1. So it is all consistent.
The Note from Table 7.1 "The measuring accuracy details only apply when using the precision rotating and sliding plates as well as the BMW quick-acting clamps" suggests that this required accuracy only applies to the BMW Kinematic Diagnostic System (KDS) alignment system and that other alignment systems would use different accuracy levels.
Looking at the values in column 1, I'd say the BMW system is pretty accurate.
However, going back to comments made about the tech being the variable in measurement, I'd say that the system may not be so precise (repeatable) as we would like, given the human dimension.
Old 01-26-2014, 11:33 AM
bluebee's Avatar
I think also, that adding the Bently-suggested weights, would also add an element of variability (since it's such a pain, most people don't).
So others benefit from my experience, here's how I weighted mine last I took mine in for an alignment...
Just in case anyone wants ideas for the proper weights, here's what I used:
- One users quest to diagnose uneven tire wear on the inside edge due to excessive and uneven alignment camber & toe (1) (2)
See also:
- Which of the dozen alignment specs are adjustable on the BMW E39 (1) (pdf) & cn90's front (1) (2) and rear (1) wheel alignment DIYs & how to keep the steering wheel (SW) straight during home alignment (1) (2) & what tools measure rear camber at home (1) (2) and what tools measure front/rear toe at home (1) & what tools lock the steering wheel & brake pedal at home (1) & the theory of alignment with weights (1) or without adding weight (1) (2) (3) & philosophically why most people prefer to let a professional alignment shop align their suspension (1) & what expensive equipment is used at the stealer to align your suspension (1) (pdf) & Internet references for how to DIY caster, camber & toe at home (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39)
