Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
Z3 (1996-2002) and Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
Z3 passenger seat moves.
My passenger side seat slides back and forth slightly. All electronic controls work and its as if the seat is loose on the track. It will shift forward or back freely for about a half an inch. Not so bad if someone is sitting in it, but when I'm driving alone, I hear it move if I accelerate quickly or brake hard. I can grab the seat with my hand and just slightly move it back and forth without using the switches. Does not sound like the motors in the seat are being affected by the movement. Any ideas?
Yes,
PM with your email address, I'll send you a detailed power point slide show on how I fixed it. |
Your seat bushings are worn out. This is a common problem with Z3's. You need to get Doug Whalen's seat bushings and replace your old ones. It's a straighforward fix and EOD Guy's presentation will most likely show you how.
2008 335i 2001 325i retired 2000 M Roadster Imola Red retired ![]() 1998 Z3 2.8L retired |
If EOD's slides don't show ya, you can also check out Rachel's pages.
PM sent...
2005 M3 ZCP: Alpine White 1998 M Roadster : Imola Red 2003 540i/6 M-Sport : Titanium Silver SOLD!!! |
You guys are the bestest!
Nice to know someone else shares my pain! Well, step one is to first go to dealer: I'm pretty sure my warranty will cover this. If not, I have the best resources to do it myself. Thanx a million! |
If the dealer does it under warranty, they will just put more crummy rubber bushings in and you'll be in the same boat in another 15-20k miles. Even if you have to do it yourself, I think it's better to do it once and be done with it.
bushings
I replaced both seat bushings for about fourty bucks. This is an easy fix. I noticed that another member is sending the instructions. Just follow each step, and you will be amazed at how easy this procedure is. I also fixed my glove box sag using the instuctions given by a member and also was an easy process knowing how.
Also, the more you do, the more confident you are to do other things.
my glove box hangs down, and i noticed someone had the same problem. what's the solution?
![]() TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix |
The seat bushings also worked great, but were a little tougher to get in. That whole "bushings surrounding a block" was a little overengineered, IMHO. They could have done without the bad bushings, and just made the block larger.
I have the same problem. Can you PM the Powerpoint to me also?
Thanks |
I need to do the same....
Can I also get that PPT presentation? Will that tell me what parts I need to get? Thanks
Could I also get your PPT of how to fix the passenger seat? I appreciate it.
All I've been away for awhile, Did everyone get the ppt that wanted it? Thanks
Dave |
Can you email me the info?
www.emeider@ecmdesign.net Thanks! |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
