E36 (1991 - 1999)
Old 10-28-2007, 08:31 PM
e36tuner e36tuner is offline
Mein Auto: 1994 325is
Exclamation Aftermarket spring on stock m3 shocks and struts
I have seen this before. My question is can the stock struts and shocks of a e36 m3 stand up to aftermarket springs or will they blow? If so how long do I have. I am thinking about this set up and have seen it done on DTMpower but I just want to make sure with you guys before I drop any money down on anything.
Old 10-28-2007, 08:52 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
If you have springs that drop the car any, they'll blow, because the compression on them will be higher. You'll get lucky if you even get a week out of them unless you drive on roads of glass without a trace of a bump on them.
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 10-28-2007, 09:11 PM
ok. cause my original setup will be h&r with koni or maybe bilsten? who do you prefer?
Old 10-28-2007, 09:15 PM
I Am The Machine
I'm running H&R's over Bilsteins. Both Koni's and Bilstein's are good shocks, but I honestly don't know how they compare against each other. I don't think you'd go wrong with either, though.
// Chad //
You're a derbanana
Old 10-28-2007, 09:22 PM
good thanks. how much of a drop do you have for front and back?
Old 10-28-2007, 09:34 PM
I Am The Machine
1.5" front.
1" rear.
If you look around, you'll find some pictures of my car here. I've posted many times. I think its pure sex
Lol.
// Chad //
You're a derbanana
Old 10-28-2007, 09:41 PM
I do to. I love the drop on it is perfect. So how does the m3 catback sound?
Old 10-29-2007, 02:51 AM
I Am The Machine
Personally, I think its exactly how it should be. Almost dead silent on idle, and you don't hear it whatsoever while cruising on the freeway. Hit the gas and you have a bit more sound. When I added the CAI, it turned into quite the nice growl. With the CAI & M3 Catback, its still quiet @ idle/cruising, but floor it, and it bites.
That said, I haven't heard many other aftermarket CAI's other than ricey fart cans on E36's, so I can't compare. I know there are other ones as well.
// Chad //
You're a derbanana
Old 10-29-2007, 09:21 PM
How do you know weather you have an m3 catback on? Becuase my e36 325is has a deeper tone than most ones that I drive by. It nice and deep around 1000-2500rpms then it gets a bit louder a at 3000+. I mean you can really hear this exhaust and it pretty deep at idle.
Old 10-29-2007, 09:35 PM
I Am The Machine
The muffler is much larger and hangs down lower, its stainless steel I think (fact check please), and it sticks out farther. It's a bit larger tips, and they're staggered (inner one sticks further out than outer one).
What yours could be is "debaffled". There is a baffle blocking your 2nd tip on the stock exhausts until about 2500 RPM's and up. This keeps it quiet. A lot of people remove the hoses that close that baffle so it remains always open, which is probably what yours is. Gives it a much nicer sound.
// Chad //
You're a derbanana
Old 10-29-2007, 09:59 PM
yeah it does. i like it. just need to be a bit louder.
Old 10-30-2007, 04:51 PM
I Am The Machine
If you just want it louder but you like the tone, get a cold air intake. It will really give it the "bite" and loudness that I think you're looking for.
// Chad //
You're a derbanana
Old 11-03-2007, 12:19 AM
cool thanks.
