E46 M3 (2001-2006)
Old 01-20-2008, 05:48 PM
edgar620's Avatar
edgar620 edgar620 is offline
Mein Auto: M3-Imola Red Interior
Originally Posted by Royce View Post
Thanks for the input Terry
I was looking into 265 all around so I could possibly rotate my tires...except since I have 8'' wide rims on the front and 9" wide rims (stock 18" wheels) on the rear figured that would not be an option (to rotate) also afraid 265's on the front 8" rim could be too wide a tire...
I like the 245 265 setup now that they are on....
Oh my M3 problem in Tyler texas (I mentioned above) turned out to be the coilpaks. Funny thing ...before I purchased this 2003 I looked at a 2002 where the guy had just replaced his coil paks...guess that's the E46 M3's weak link...
What is the "coilpaks"? What does it do and where is it located? Also how much was it to replace?
Old 01-20-2008, 05:51 PM
edgar620's Avatar
Never mind I know what your talking about. My bad.
Old 01-21-2008, 12:00 PM
ckk ckk is offline
Mein Auto: 2002 M3
sayemthree, thanks for the tire advice. Now I just need to wait for a set of rims to appear on the used market :-)
For 265, does anyone have an opinion on 9 vs. 9.5" wheels -- I assume 9.5" rims might rub more in the front, but the tire should be a little happier on the wider rim
Also, what happens to the offset if I get 9.5" wide rims?
Old 01-21-2008, 12:31 PM
sayemthree's Avatar
sayemthree sayemthree is offline
Mein Auto: 2008 M3
you may want to call tire rack - they may be helpful on this.
2008 M3 Coupe 6MT Jet Black
2008 X3 3.0si 6MT M sport
2008 GTI 4 dr. 6MT
2004 X3 3.0i 6MT
2008 X3 3.0si 6MT ///M-sport package
Old 01-24-2008, 09:42 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Originally Posted by ckk View Post
Do I need to do anything special to fit 265's in the front (other than buy wider wheels)?
I'm thinking about getting some track wheels, and I like running non-staggered to reduce understeer...
Thanks,
--Carey
I don't know, but I have seen them run on stock fronts with just the camber pin pulled.
To fit a set of stock rears up front with 265s, you need to swap the hats also.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 01-29-2008, 08:32 PM
Rascasse Rascasse is offline
Mein Auto: M3, Ferrari 348
I use the 245/275 set up and I like the way the car handles.
Ciao.........Dino
M3
AM V8 Vantage
348 SS Challenge
SL55 AMG
Ducati 916
March/Cosworth Indycar
www.VelocePerformance.com
Old 01-30-2008, 03:37 PM
sayemthree's Avatar
Mein Auto: 2008 M3
I have run 265 up front on rear wheels, no problem. only mod is the camber pin pulled.
2008 GTI 4 dr. 6MT
2004 X3 3.0i 6MT
